electrical problem.....HELP!!!
Old Jun 22, 2007 | 11:46 PM
vathman27's Avatar
Exclamation electrical problem.....HELP!!!
2003 MT6. A/C will not turn off. Radio will not turn on. None of the buttons work for the radio or A/C. No lights on any of the buttons. Any ideas.
Thanks,
Ken
Old Jun 22, 2007 | 11:57 PM
k67p67's Avatar
Sounds like your climate control harness is not plugged in. It will cause all the symptoms you described.
Old Jun 23, 2007 | 10:30 AM
vathman27's Avatar
Thanks for the feedback. Where and how can I check to see if this is the problem. Any other ideas.
Much Thanks,
Ken
Old Jun 23, 2007 | 10:52 AM
GreenGoblin's Avatar
The goblin resurrection
I would start out with fuses check them all
Old Jun 23, 2007 | 03:55 PM
vathman27's Avatar
Thanks guys....
I found the problem.....It was the fuse in the fuse box next to the battery. The fuse was not blown, but I did pull it out and reseat the fuse. I also made sure the relays were all seated. Works fine.
Old Jun 23, 2007 | 03:59 PM
glad that you found the problem.
Freeman186
Sep 6, 2023 10:07 AM
Danielek
May 1, 2022 01:28 PM
RemmyZero
V36 DIY
Apr 23, 2018 11:13 AM
vamarris
Sep 26, 2015 12:56 PM
