Had Alarm Installed, Now Climate Control is Messed up!!?!
Old Jul 3, 2007 | 04:32 AM
Jining's Avatar
Hello! Today I had an Auotpage RS-900 installed in my G35 coupe. Now, for some reason when I turn on the automatic a/c, even if its 70 outside and I set it to 65, heat comes out, it never used to do this. Then, if I set it to 70 and its 70 outside, it would usually turn off since the temps are the same, but it keeps on blasting warm air at full blast.
Do you think the in-car temperature sensor is messed up due to the alarm install? If so, does anyone know where it is located so I could check it out?
Thanks a lot!
Old Jul 3, 2007 | 08:21 AM
RaFmAn123's Avatar
hey i install alarms and i had this happen to me when i did a z last year. the panel under the stearing wheel has a little vent looking thing on the front well right behind that has a hose looking thing and a plug when they took the panel off they unplugged it and forgot to plug it back in. once that is plugged in everything will work back fine.
Old Jul 3, 2007 | 03:36 PM
Jining's Avatar
Sweeet! Thanks figured it out last night!
Z1Motorsports
Suspension-Vendor
56
May 31, 2020 01:56 PM
WillisFL
Dec 29, 2016 08:56 AM
JMSABO
Aug 4, 2015 11:58 AM
itschuckster
Jul 25, 2015 08:07 AM
apintojr
Jul 23, 2015 10:52 AM
