Dome light size
Old Mar 2, 2004 | 02:30 PM
docron1's Avatar
From: Centerburg, Ohio (the geographical center of the Buckeye State)
Re: Dome light size
For exact lighting bulb specs, see the following spreadsheet.
http://www.geocities.com/lakerscentral/g35lights.xls
It has info (size, part numbers, etc.) for all the bulbs in the ENTIRE G35 coupe!<P ID="edit"><FONT class="small"><EM>Edited by joepaniolo on 03/02/04 11:31 AM.</EM></FONT></P>
Old Mar 3, 2004 | 10:36 AM
fluffydot's Avatar
Re: Dome light size
can someone please offer some advice for openning the door/step light cover?
it's a wierd L-shape so I'm not sure where the clips might be etc...
there is a picture somewhere in the forums, but it's not clear at all...
which side should I pry from ?
Old Mar 15, 2004 | 08:29 AM
g35audioman's Avatar
Re: Dome light size
joe...i dont have excel..can you cut and paste that info for me? I'd really appreciate it. I've been looking for that info online. Thanks.
Old Mar 15, 2004 | 03:15 PM
Gordgee's Avatar
Administrator
Re: Dome light size
A cut and paste looks like this. The chart may be hard to read if posted in it's entirety.
<font color=blue>G35 Lighting (d= diameter, l=length, w=width, h=height)
Interior: Owners Manual Actual Bulb # Sylvania Part # Chiltons Bulb Type Bulb Dimensions Casing Description
• radio lights 11 "black sockets" @3.0W + 3 "brown sockets" @1.4W ? White bulbs w/ orange film? *or* tons of small orange bulbs?
• temperature & compass display
• center console buttons
• door buttons [windows & door locks]
• gauge displays
• ignition [key ring] lamp (1 pc) 48476-AV700
• vanity mirror lights 1.32W X 26447-AM660 soldered 19mm L x 4mm D 53mm L x 5 mm H
• clock light (1 pc) 24860-AM600
• glove box (1 pc) 24860-2J001
• dome [reading / map] lamps 8W Toshiba A12V5W DE3175 26447-AL500 festoon 30mm L x 10mm D
• step [courtesy] lights 5W Toshiba A12V5W DE3022 26447-AL510 festoon 28mm L x 8mm D
• trunk [luggage / cargo] light (1 pc) 3.4W Toshiba 158 158 26261-89900 wedge 24mm L x 9mm W
Exterior:
• front turn signals 21W / T20 7440 ? 26261-89949
• rear turn signals 21W / T20 7440 ? B671K-C9940
• reverse [back-up] lights 18W / T16 921 26261-89917
• license plate light 5W / T10 168 26261-89967 wedge
• clearance strip lights 5W / T10 168 X wedge
• front side marker [corner] lights 3.8W / T10 194 194 26261-04W00 wedge
• high beam [fog / driving] headlamp H4 9003 26297-89910
• low beam [regular] headlamp HID HID-D2R 26294-89910 xenon
• rear side marker [corner] light LED X X LED
• stop [tail] light LED X 26261-89949 LED
• high mount stop light LED X 26590-AL250 LED
PIAA:
H4 Xtreme W #15260, Super Xtreme #15760, Super W Platinum #15660, Super Plasma #15560, Super Plasma GT #15960
158, 168, 194 (wedge) Xtreme W #19172, Super W #19168, Platinum Super W #19169, Super Plasma #19170, Plasma B #19171, Ion Crystal #19173
158, 168, 194 (wedge) LEDs #19261-3 High Intensity LED [B / BW / W]
DE3022, DE3175, T-6 Xtreme W #19223
7440 Xtreme W #19225
921 Xtreme W #19224
RAYBRIG:
H4 RR41 (magnum w), RR44 (thunder w), RR45 (sonic w), R289 ?, R298 ?
DE3022, DE3175 R104, R117 (original W), R133 (super W), R134?, R141 (P), R152 (B & P), R153 (G & P)
158, 168, 194 RC11 (h-B) LED, RC12 (h-W) LED, R103 ?, R110 (B), R111 (G), R130 (h-W), R142 (h-P), R154 (B & dark-G), R155 (B & light-G), R156 (light & dark G)
POLARG:
DE3022, DE3175 M16/28 (super W)
158, 168, 194 G51 (A), G52 (B), G53 (R), G54 (h-W), J-01 (h-W) LED, M4 (super W)
7440 M1 (super A), M2 (super W), M15 (super B)
921 M5 (R), M6 (super W)
SOEI:
158, 168, 194, 12256, 12961 SE235 (yellow/purple/red), SE350 (blue) LED
DE3021,22, DE3175 SE520 (purple/green/red), SE525 (purple/green/red)
SuperBrightLeds.com:
DE3022, DE3175 (12vdc, 31x10 mm) 2 leds: 3022-2 W/B/G ($1.95) R ($1.20) UV ($2.70); 4 leds: 3022-4 W/B/G ($2.35) R/A ($1.60) UV ($3.45)
158, 168, 194 (12vdc, 1 1/8"L x 1/2" diam) 1 led: WLED- W/B/G ($1.50) R ($.90) A ($.80) UV/P ($1.50); 2 led: WLED-4 W/B/G ($2.60) R/A ($1.60) UV ($2.60); T13-6 W/B/G ($3) R/A ($2)
7440 (12vdc 15mm) 9 leds: 7440-A9 ($4)
** for bulbs with low heat output (i.e. interior)-- may be able to put acetane sheet or spray the lens instead of replacing the bulb
<font color=blue>GroundingGear™ Equipped </font color=blue>
marsman328
Northern California
Aug 11, 2015 07:29 PM
Cam_Cooper3
Intake & Exhaust
Aug 10, 2015 07:04 PM
Cam_Cooper3
Aug 4, 2015 01:53 PM
julian.dion
Jul 29, 2015 09:16 AM
