Heel/Toe impossible....
Old Jan 25, 2004 | 10:16 PM
Shader7's Avatar
Re: Heel/Toe impossible....
My accelerator is right under my heel when I slide it over. You know heel-toe is most often performed under heavy braking right?
Black/Willow 03.5 6MT, Premium, Navi, Aero, SAT
350Z Nismo CAI
Old Jan 26, 2004 | 12:03 AM
TuPaK's Avatar
yep, exactly. heavy breaking.
If the accelerator pedal is too far down, that means you aren't breaking hard enough, and that means you don't need to really heel-toe at that point.
Coming into a turn, where you need to slow down significantly is the best opportunity to try heel toe. Remember, just slide your heel over, and give the pedal a quick jab to raise rpm then you can immeditaly slide it back and release clutch.
04 Black G35C 6MT | Premium | Navigation | Grounding Kit
Old Jan 26, 2004 | 12:22 AM
nuttyprof's Avatar
when i practice heel/toe, i am usually going too slow. but then when im going faster, im afraid to do it becuase i havent practiced it enough to feel comfortalbe. ahhh dillema
G35S 6MT
Technosquare ECU
350Z Springs & Struts
6-wire ground kit
Old Jan 26, 2004 | 09:33 AM
RyanGSanders's Avatar
I do it very seldom...of course, having small feet means that it's a true pain in the a$$ for me...but it can be done.
If you're looking for a pedal setup that is really helpful, try the Sparco carbon fiber pedals. Just don't try driving with expensive dress shoes :-)
BASIC BLACK
Old Jan 26, 2004 | 10:37 AM
Shader7's Avatar
It's also often done in corners to get a better downshift flywheel speed for a faster exit. I practice it on onramps if I find myself alone.
350Z Nismo CAI
Old Jan 26, 2004 | 11:14 AM
retret's Avatar
I also have the same problem, clutch is not a problem, the major problem is the height difference of the brake pedal and the gas pedal, and if I brake hard its still level with the gas pedal, I maight end up using toe for the gas and heel for the brake..
ScapGF
Aug 1, 2005 04:48 PM
