Keyfob Programming Options
Old Jan 25, 2004 | 12:02 AM
G35_4EVR's Avatar
Someone from FA posted some keyfob programming options
and I wanted to know if anyone had to pay to have the factory settings changed to your preference prior to taking delivery of your G35? I was told there was a charge of $90/hour if I wanted to make any changes and that I should consider staying with the factory settings before making any changes. Can anyone tell me what the factory settings are?
Here's the list that I saw in FA:
Door Lock/Unlock (with single click on keyfob)
Mode 1: Unlock left front door only
Mode 2: Unlock all doors
Anti-lock Out (prevents locking keys in car)
Mode 1: Master door lock switch can activate door locks w/ key in ignition
Mode 2: Master door lock switch cannot activate door locks w/ key in ignition
Dome Lamp Timer
Mode 1: Interior lamp comes on when left front door is unlocked
Mode 2: Interior lamp does not come on when left front door is unlocked
Retained Power (Amount of time windows and sunroof will operate after turning off ignition)
Mode 1: 45 seconds
Mode 2: No delay (Will not operate after ignition key is turned off)
Mode 3: 2 minutes
Auto Light On (headlights turn on as it gets dark)
Mode 1: Factory setting
Mode 2: Lights come on sooner than factory setting
Mode 3: Lights come on later than factor setting
Mode 4: Lights come on later than Mode 3
Head Lamp Battery Saver (applies when headlights left in “on” position, not in “auto.”
Mode 1: Shuts lamps off after 5 minutes
Mode 2: No time delay (headlights turn off immediately)
Headlamp Illumination delay (time headlights remain on after exiting car when headlight is in the “auto” position)
Mode 1: 45 seconds
Mode 2: No Delay (lights turn off immediately)
Mode 3: 30 Seconds
Mode 4: 1 minute
Mode 5: 1 ½ minutes
Mode 6: 2 minutes
Mode 7: 2 ½ minutes
Mode 8: 3 minutes
Hazard and Horn Reminder Mode (key fob allows you to choose between modes 1 & 2, but there are 4 others)
Mode 1 (C Mode): Lock = 2 flash, 1 horn /// Unlock = 1 flash, 0 horn
Mode 2 (S Mode): Lock = 2 flash, 0 horn /// Unlock = 0 flash, 0 horn
Mode 3: Lock = 0 flash, 0 horn /// Unlock = 0 flash, 0 horn
Mode 4: Lock = 2 flash, 0 horn /// Unlock = 1 flash, 0 horn
Mode 5: Lock = 2 flash, 1 horn /// Unlock = 0 flash, 0 horn
Mode 6: Lock = 0 flash, 1 horn /// Unlock = 1 flash, 0 horn
Remote Auto Locking Function Mode (Doors automatically lock after exiting car)
Mode 1: 5 minute delay
Mode 2: Function disabled
Mode 3: 1 minute delay
Remote Panic Alarm Operation Mode (activates when button on keyfob held for approx. __)
Mode 1: .5 seconds
Mode 3: 1.5 seconds
Remote Trunk Open Operation Mode (activates when button on keyfob held for approx. __)
Mode 1: .5 seconds
Mode 3: 1.5 seconds
Remote Power Window Down Operation Mode (activates when button on keyfob held for approx. __)
Mode 1: 3 seconds
Mode 3: 5 seconds
2004 Coupe/DG/5AT on order...Is it here yet?
Old Jan 25, 2004 | 12:57 AM
C_Lawd's Avatar
Re: Keyfob Programming Options
There has to be a way to change these settings without a visit to the dealer...
'04 DG Coupe
Old Jan 25, 2004 | 08:53 AM
G35_4EVR's Avatar
I believe there is a way if you have Nav, but I don't have it and the only way to change the settings is at the dealership that has the required equipment to change the factory settings.
Old Jan 25, 2004 | 09:50 AM
Meatshackle's Avatar
Deep Sea Moderator
Unfortunately there is no other way, even with the Nav. The only thing you can change is the horn and light option for locking and unlocking.
Russ
Black 6MT Coupe
Jax, FL
PS2 and Headrest thread
Old Jan 25, 2004 | 11:38 AM
newbie35's Avatar
How do you arm the alarm silently?
I would think that Infiniti would provide that as an option that we could use.
2003 IP Coupe. Non-Navi. 19" DTM Kreuz 7. V-Kool & Metallic Tint.
Old Jan 25, 2004 | 02:48 PM
G35_4EVR's Avatar
TrentaCinque:
Does the owner manual explain how to disable the horn and light option for locking and unlocking? My car is being delivered by the end of this week and I'll change that almost immediately.
2004 Coupe/DG/5AT/Premium on order...Is it here yet?
Old Jan 25, 2004 | 03:04 PM
Gordgee's Avatar
Administrator
I had my BCM reprogrammed back in November 2002, one of the first done I believe.
Here's the BCM Control Module Customization Chart
Unfortunately, I believe the only way to do it is with the Consult II device. They may charge you for any changes made.
<font color=green>GroundingGear™ Equipped </font color=green>
Old Jan 25, 2004 | 04:33 PM
G35_4EVR's Avatar
Thanks for the info Gordgee.
Old Jan 25, 2004 | 07:37 PM
Canton_G35's Avatar
you hold the lock and unlock button down at the same time for about 3-5 sec.
if it works either the horn will sound or the lights will flash. depending on which mode you're switching from.
2003 G35 Coupe 6MT/Black/Graphite/15% tint/6 wire GroundingGear™
Old Jan 26, 2004 | 11:20 AM
G35_4EVR's Avatar
Canton G35 -
Thanks for the additional info on changing the horn and light function with the keyfob.
Old May 31, 2005 | 02:26 AM
richboy's Avatar
MORE POWER PLZ!!!
does the dealer do this for u or could u do it yourself?
Old May 31, 2005 | 02:28 AM
TopTech's Avatar
Read # 4. The dealer does anything else. Some charge thru the a$$, others give it away.
Old Nov 5, 2010 | 06:49 PM
Atsang's Avatar
i have a 07 coupe 6mt no nav. I went to the dealer to have them change my alarm to auto lock but they said that this option wasn't available on my car. were they bSing me?
Old Nov 9, 2010 | 09:17 PM
sillyoldtayo's Avatar
I have an 06 6mt and I have noticed that ive left the car unlocked, walked away, come back, only to notice the doors were locked. Im not sure if I accidentally hit the button or if the doors locked automatically. its happened 2 or 3 times. Time to test this!
Old Nov 10, 2010 | 12:44 AM
TripleHBK's Avatar
If you unlock your door but do not open it within a minute or so the doors will automatically lock. I've never had my doors lock on their own though after turning the ignition off and just walking away. Only if I hit unlock first then didn't open the door.
prinny
Nov 22, 2015 11:07 PM
Detailed Image
Sep 18, 2015 03:43 PM
Detailed Image
Sep 17, 2015 07:38 AM
