problem with interior dash lights
just a few days ago my shift lights has been cut off(the P,R,N,D) , as well with the left heat seat buttom light, is there anything i can do to make those back on?
have a service manual? in the 07's, shows how to do Self-Diagnosis Mode of Combination Meter
SELF-DIAGNOSIS FUNCTION
Odo/trip meter and A/T indicator segments operation can be checked in self-diagnosis mode.
Meters/gauges can be checked in self-diagnosis mode.
OPERATION PROCEDURE
1. Turn ignition switch ON, and switch the odo/trip meter to “trip A” or “trip B”.
NOTE:
If the self-diagnosis function is activated with the “trip A” displayed, only “trip A” display is reset.
2. Turn ignition switch OFF.
3. While pushing the odo/trip meter switch, turn ignition switch ON again.
4. Make sure that the trip meter displays “0000.0”.
5. Push the odo/trip meter switch at least 3 times (within 7 seconds after the ignition switch is turned ON).
6. All the segments on the odo/trip meter and A/T indicator illuminate, and simultaneously the low-fuel warning lamp indicator illuminates. At this time, the unified meter control unit is turned to self-diagnosis mode.
7. Each meter/gauge activates during pressing odo/trip meter
switch. (Then low-fuel warning lamp turns OFF.)
OPERATION PROCEDURE
NOTE:
as to seat heater, if pass seat works, then no a fuse problem nor seat heater relay problem. Does seat still heat and just no light? check under driver seat for loose connector, connects thermostats to heater element.
