XM to SIRIUS conversion
Old Aug 6, 2007 | 05:59 PM
infiniti06's Avatar
i have o6 g35 coup and have factory xm radio and i was wondering if anyone knew of a way to get sirius radio using the xm antena and the stock radio. Ive heard of it done on chevy cars and ford cars but nothing about infiniti.
Old Aug 6, 2007 | 06:42 PM
kernel's Avatar
SEC > Big 12
You may be able to use the same antenna, but i'd imagine a different tuner would be necessary.
Or you could wait till the merger is approved/completed
Old Aug 6, 2007 | 06:51 PM
Mike_Deezy's Avatar
You can use the same antenna, but you have to get a Sirius tuner. I know this for a fact becuase one of my friends drive an Altima and it came equipped with XM and all she did was swap out the tuner and it worked perfectly.
Old Aug 9, 2007 | 08:54 PM
daveblank's Avatar
The antenna will work but it will need 1 small modification. Where it plugs into the tuner are 3 ribs. ! is in a different place from XM to Sirius. Take a razor blade & trim the different rib & you're good to go. I've probably done 50-75 of them & it's no big deal.
Marlin84
Apr 1, 2020 12:52 PM
Extreme Dimensions
Exterior-Vendor
Oct 29, 2015 10:24 AM
twentyeggs
Sep 11, 2015 03:58 PM
06G35Kurtis
Aug 23, 2015 12:24 AM
wuppiedog
Aug 7, 2015 11:16 AM
