DIY Grounding
Old Jan 28, 2004 | 06:20 PM
Rson's Avatar
DIY Grounding
For all you cheap-skates.....I made my own grounding kit. Total cost $31.00
I went to a car audio store and asked for some 4 gauge ground cable scrap...the secret is look for scrap pieces...you can get a discount. I went to a local hardware store and got one 4 foot piece of 3/8 shrink wrap, 4 gauge connectors, one battery terminal.
2004c Graph/Graph, prem, aero, Sport
Old Jan 28, 2004 | 06:43 PM
SoCalG35C's Avatar
Re: DIY Grounding
What did you use to crimp the connectors? Did the $31 cover materials only or did that also include any specialized tools (like a 4 gauge wire crimper)?
I'd be curious to know if you notice any improvements after your install too...
Old Jan 28, 2004 | 06:52 PM
Rson's Avatar
Re: DIY Grounding
Used a screwdriver and xacto knife to cut the plastic around the wire. I cut off about 1cm of plastic and put the connector on....then I pressed it flush to the connector, used a hammer and thick flat-head to crimp it down.
Old Jan 28, 2004 | 09:02 PM
Gordgee's Avatar
Administrator
Re: DIY Grounding
My compliments. That actually looks better than some of the ones that are sold on e-bay! Make sure the crimp is really secure though, or it could add more noise to the system. You want to put a LOT of pressure on the crimp! That and the quality of the wire are the two factors in ensuring that you get an optimal H-G signal.
<font color=green>GroundingGear™ Equipped </font color=green>
Old Jan 28, 2004 | 09:57 PM
Rson's Avatar
Re: DIY Grounding
I appreciate the post and hint....after seeing Stillens kit I knew I could make the same. Afterall, it was Tsunami Car audio cable. I got Lightning Audio 435 strand 4 gauge cable.
That crimp is pounded tight. THanks for all your input "G".
Old Jan 29, 2004 | 01:09 AM
waijai's Avatar
i.love.gold
Re: DIY Grounding
The crimps on my kits are tight too.
Ivory Pearl coupe
Marlin84
Apr 1, 2020 12:52 PM
RemmyZero
V36 DIY
Apr 23, 2018 11:13 AM
Ninjay16
Audio/Video/Electronics
11
Feb 26, 2018 06:14 PM
prinny
Nov 22, 2015 11:07 PM
