2007 - inherent problems?
Old Aug 28, 2007 | 10:26 AM
1991NSX's Avatar
I did some searching and read about the G's problem with the CD changer(I'm assuming it's the in-dash 6 disk Bose unit). Is there a problem if you just put 1 CD in at a time to listen to?
Also, read about some rear axle bolt coming loose??? How do you know if this is a problem, what does the car do? Any other issues that are common to an 07 that I should be aware of?
My gas pedal is light to the touch(very little resistance), can this be adjusted to make it a little heavier to push down on? Drives me nuts to try to keep my foot constant, all my other cars have greater resistance and is far more comfortable to drive.
Thanks!
Old Aug 28, 2007 | 11:00 AM
Memphoman's Avatar
My changer was changed out in my 2nd month and I did have 6 disks loaded. 5Kmiles thus far, recently had my fuel tank sending unit replaced, tank would not show full.
Freeman186
Sep 6, 2023 10:07 AM
mattdg35
Sep 14, 2015 11:28 AM
eljefe7070g35
Sep 11, 2015 09:28 AM
spanky99l
Sep 7, 2015 12:46 AM
Jnm07
Sep 5, 2015 01:16 AM
