Ambient air temperture sensor
My sensor has been been flaky of late, sitting in my driveway, turned car on and it was reading 135° most of the time it reads normal ± a couple of degrees. I noticed that immediately after washing my car, it would read considerably lower, and, over time would eventually climb back to normal. Other day, outside temp was 108°, washed my car, and soon after it was reading 86°. Took in in to the dealer today, and they replaced the sensor, but, they also told me that to read significantly lower after car washing was "normal" and that it should correct itself by about 16° per hour. Since this reading has a direct impact on cooling of air conditioning, I wonder about this?
It reads the ambient air temperature in the nose of the car right in front of the radiator. It will read most accurately when the car is moving (exchanging air). It will read very high if the car is driven, and then parked for a while where the radiator will heat the air in the nose. Water evaporating (like after a wash) will lower the temp also. Only trust the temp either when the car hasn't been driven, washed, etc. for a long time and it's not in direct sun, or you've been driving at a decent speed for a minute or two.
There is a temp sensor inside the car (not outside) that controls the a/c.
You're getting a high reading when parked on pavement due to the reflective heat adding to the air temp (especially in LV). I frequently notice that the outside temp drops 10+ degrees within a few minutes after leaving a parking lot and getting on the freeway.
Mad A
Not G35 Related
Dec 8, 2015 01:45 PM
n2fooz
Sep 4, 2015 07:46 PM
