Solved my rattle trap (figure this one out)
1) My seat was squeeking like a bitch, so I raised it as high as possible, 12/14mm socket to the back 2 bolts, re-adjusted the seats (by pulling it more towards the door), and bang, no more problems with my seat (apparently a common problem/fix)
2) (Figure this one out) I kept hearing a squeek coming from my driver side fender. After almost 1yr I finally figured it out - my (stock) hood was rubbing a hole in my air conditioner line! It's literally frayed right through (and where the hood is making contact, the paint on the underside is worn off). So I took some high temp. exhaust tape and wrapped up my air conditioner line where the hole is, making a HUGE bundle from the tape (to act as a pad). Bam, no more squeeking.
Has anybody ever heard of a stock hood (w/ stock airbox) rubbing a hole through the air conditioner line???? I've heard of the line getting frayed with aftermarket air boxes if it isn't secured properly, but stock, WTF?
Learned Hand
Oct 1, 2015 09:02 AM
