2007 G35 Passanger window problem
Old Sep 9, 2007 | 11:41 AM
vtboomamj's Avatar
Hey fellas, I recently purchased a new G35 and I am having problems with my passanger side window. What happens is when I try to roll it up. It will roll up all the way and then immediately rold down about 3 inches and stay. I looked at the window alignment and it looks good but you know, how would I know what good and bad is? I'm going to take it to the dealer today and tell them. Has anyone else had this problem before? Thanks!
Old Sep 9, 2007 | 01:39 PM
GR8TG35's Avatar
This is a common problem with the window regulators on the G......Take it in to the dealer, and they will most likely replace the motor.......
This has been going on since the first 03 models.......I replaced my driver side a year into ownership.....You think by now they would have found another supplier with a better motor..........
Old Sep 9, 2007 | 04:49 PM
SteveBlake's Avatar
I have an 07 also and had the exact same problem. I just manually rolled it up by holding the button up and not doing the automatic roll up, turned off my car, turned it back on, and it was fine.
Old Sep 10, 2007 | 02:43 AM
Memphoman's Avatar
mine did it too, they attempted to re-calibrate it, but, on 2nd problem, the replaced the motor.
Old Sep 10, 2007 | 09:55 PM
luder's Avatar
That's how it starts, and then the motor go ku-putts. :/
I'm 'bout sick of Infiniti, with this and the damned clock light bulbs.
wonderizm
Sep 24, 2015 03:09 AM
netcbc
Exterior - Body Parts CDN
Aug 21, 2015 09:50 AM
laksjd84
Jul 24, 2015 05:12 PM
attarday
Jul 15, 2015 04:03 PM
