So, what DOES void the warranty?
Old Sep 11, 2007 | 03:41 PM
express705's Avatar
Question So, what DOES void the warranty?
does an injen ses exhaust void my warranty?
and, what voids your warranty?
Old Sep 11, 2007 | 03:46 PM
Dustin@StrafeAutomotive's Avatar
Really Needs a Life
pretty much most things you change will do so.
Old Sep 11, 2007 | 04:03 PM
redlude97's Avatar
anything that directly affects the warrantied item in question can void the warranty
Old Sep 11, 2007 | 04:06 PM
AthensBlueG's Avatar
Brian
All the responses so far are correct, in so far as I understand warranties.
What you need to understand is, there is not a single warranty that covers the whole car. There is a warranty on all individual parts of the car. Changing a part will void the warranty for that part, but not the entire car.
express705's Avatar
that means exhaust voids the warranty...
Old Sep 11, 2007 | 04:07 PM
Jtrain's Avatar
asking this question AGAIN
Old Sep 11, 2007 | 04:08 PM
g35man04's Avatar
CLUB MODERATOR
yes the exhaust can void the warranty....most of the time if you have mod friendly dealerships around then you wont have to many issues....
Old Sep 11, 2007 | 04:13 PM
Hi-TechG35's Avatar
Anything you change voids the warranty. ie:exhaust, intake, headers, spacer etc. But if you have problems it is up to the dealer to show proof that the modification caused the problem before they can tell you you are not eligable for warranty.
Old Sep 11, 2007 | 04:16 PM
g35man04's Avatar
CLUB MODERATOR
+++++1 and amen to the answer Hi-tech
Old Sep 11, 2007 | 06:38 PM
Beebo's Avatar
like Hi-Tech_G said make sure the ****ers prove it was the mod
Old Sep 11, 2007 | 06:55 PM
Jtrain's Avatar
Okay my real answer is, I had every NA mod you could do besides building the motor, and I got a new tranny.
An exhaust isn't going to give you greif. Unelss you are leasing this, then I wouldn't really mod it unless you big baller.
Old Sep 11, 2007 | 07:20 PM
LjN_728's Avatar
An air freshener will void your warranty
Old Sep 12, 2007 | 05:36 AM
ISMSOLUTIONS's Avatar
Turning the key in the ignition, using the key fob, putting gas in the car, using the gas pedal, using a turn signal, adjusting your mirrors, turning on and off the stereo, parking the car, using the brakes, and shutting off the car - all of these things can lead to the car not being covered under warranty for various things.
It depends on the dealer, your service writer, the service department policy (mod friendly or not). If your a really good person with a good attitude or not, that could work for or against you ;-)
The bottom line is - abuse or modification of a vehicle, over and above reasonable use and reasonable wear and tear - would be subject to warranty claim issues.
An example of how an exhaust system could affect warranty repairs:
The aftermarket exhaust could be built wrong, so the other components that are stock, like CATS or manifolds, may crack or fail prematurely - likely not covered under warranty.
Front end noises, alignment or tire wear issues, on a car with sway bars or lowered springs or high performance shocks/struts - may kill warranty opportunities.
Anything that makes the car perform better, or worse, than factory designed - can kill warranty availability - including those items that would normally be covered under warranty - like defects or common TSB's.
Axle clicking - HUGELY common, but might not be covered if the car is lowered - it can be argued that the change in suspension geometry caused too much stress and the issue is the result.
The big stereo, lots of bass, etc...mya kill the creaks and rattle fixes normally covered.
So - with all of that said - it's all B.S. as well - but all possible nonetheless.
What we should all do, is buy these cars, flat bed them to our homes, garage them until the factory warranty times out, before ever using them to ensure coverage - then again, they'd find fault with that as well likely!
Bottom line again ;-) - enjoy the car - do simple bolt ons and only go major, like FI, cams, etc, if you own the car and don't care about warranty. Don't do it on a leased car, unless the money is no object and you plan on either selling to private party or saving your stock stuff to then part out the mods later.
If your THAT worried about warranty coverage, buy a car you wont want to mod, or maybe even can't.
Rick
Old Sep 12, 2007 | 10:30 AM
Vblick's Avatar
My dealer told me that the only thing I could do to the car that wouldn't void anything was an intake. So that's all I did. Once the warranty is up i'll probably at spacers etc....
Old Sep 12, 2007 | 11:28 AM
Matt at PF's Avatar
Most of the time they wont void the warranty if it has a cat back exh. Or if you have the dealer install the parts.
