Scratched my head light housing
Old Feb 11, 2004 | 10:02 PM
d3g's Avatar
d3g
I now have 3 small scratches on my driver side headlamp that probably no one will notice but me. I would like to remove them if possible. Does anyone know of a product that would safely remove the scratches from clear plastic without harm? They are not very deep but are starting to bother me more and more. I guess I’m just being picky. Thanks in advance for any help on this.
www.corevoltage.com
Stillen Box | Fallsgate Amp | Projection Fogs
Old Feb 11, 2004 | 10:36 PM
Merlin's Avatar
Staff ALUMNI
Re: Scratched my head light housing
Check your nearest autoparts store for some plastic polish. I recommend Fine grade.
Andrew, We Miss and Love You! Peace!
Old Feb 11, 2004 | 10:51 PM
GR8TG35's Avatar
Meguiars and 3M both sell a plastic polish and plastic cleaner used for this purpose.....depending on how deep the scratch is you can probably clean it up pretty good...I have used Meguiars product many times with good success...in some cases you may want to lightly and I mean lightly sand the scratch with either 2000 or 1500 wet/dry sandpaper...but make sure you keep it wet with water or maybe even detailing spray so you clean up the scratch and do not make any more work than necessary to remove them....then polish and clean with the plastic cleaners....should look brand new....I would practice on a similar material before hitting any spot on your car......practice makes perfect...
check these two places for the products
autogeek.net
properautocare.com
hope this helps...[img]/w3timages/icons/smile.gif[/img]2old4this
04 cpe ivory pearl/willow/5at/prem/sport wheel pkg/clear corners/Piaa's
Old Feb 11, 2004 | 11:20 PM
Merlin's Avatar
Staff ALUMNI
Then again that is why I had the "Clear Bra" installed on the headlights.[img]/w3timages/icons/smile.gif[/img]
Old Feb 11, 2004 | 11:55 PM
d3g's Avatar
d3g
Thanks allot guys I will get some polish tommorow. The scratch isnt really deep (cant see it unless you know its there)so polish sounds like the answer for me. Thanks again!
www.corevoltage.com
Old Feb 12, 2004 | 01:09 AM
tpware's Avatar
Pep Boys carries Safecut. It wil lget most scuffs and light scratches. I've used it on my G headlight covers to remove grime. Also inside to get a scratch off the radio face (thanks dealer!)
bs g35c lth/prem
Jusseth
Sep 13, 2020 12:25 PM
mike730
Jan 12, 2018 04:25 PM
Fireman07603
Aug 9, 2015 06:00 PM
VANST3R
Lights
Jul 27, 2015 08:20 PM
