help please!!!
help please!!!
so i have my coupe for about a year now and have a loud vibrating noise coming from the front end, took it to the dealer and was told it was from the front tires cupping and was not covered by my warrenty wtf
does anyone know what i can do to make the noise go away its really annoying
it sounds as if i was driving on a really bumpy road and the front end will vibrate
looked at the tires today and noticed that half of the tire (inside) has uneven wear
Originally Posted by 2K5-G35-C
Sounds like the tire feathering is so bad that its making something else toward the front of the car vibrating. I had the same issue, get new tires along with an alignment and youll feel alot better.
You think? I replaced my OEMs with Toyo T1Rs AND an alignment and got the feathering drone within about 10k kms.
What DID help was a track day I did which wore down some of the feather and was significantly quieter afterwards. So all I need to do is lap hard for a couple of hours periodically!
I have the same problem and it really gets me mad...as if the wheels of the car are going to fall off. im embarassed when i drive ppl cuz its so loud. But yea u need to get new tires and allignment as i will do and for the future u need to do rotations to the tires more often since this is a problem in the G's
did they put it on the lift and check for a bad wheel bearing? if not, they are lazy and dismissive, take it elsewhere. Youre going to hear most cupping, maybe feel it alittle. It would take some severe cupping to transmit that much vibration.
