Anybody NOT Have a Creaky Driver's Seat?
This is a pretty common problem.....I had mine repaired back in 05, but lately I notice its starting to creak again.
If you do a search, someone with a sedan did a DYI for this problem....many were successful in stopping the noise, but a few said it came back as well.
6MT Coupe
In the 200lb club and no seat creak yet, but thats not to say it wont happen eventually.
Isnt there a TSB on this? Thought there was and something about replacing the seat to floor steel frame? But dont quote me on that.
Originally Posted by cryhavok
I get a lot of squeek/rub sounds from the seatbelt rubbing on the shoulder of the seat...very annoying
I'm not going to say anything about not having a seat squeek, cause that will start it.
Ive heard of this, my passenger seat sqeeked really bad over bumps and COsta Mesa infiniti replaced the whole seat mount. Costa mesa is really good for the small stuff. FOr the big, I am currently going through Riverside Infiniti
I've had this problem for over a year, and it was so annoying. Went to the dealer three times... first time they greased everything; second time they replaced the seat rails; third time they said nothing can be done about it. Finally, i found my own fix:
Get two heavy-duty spring lock washers and place them under the two bolts in the picture. Then, tighten both bolts fairly well (but not too tight, or you'll break the bolt right off). That should fix the creaks...
I had this problem with my 03 coupe. The dealer fix it -didnt charge me but they said that it wasnt under warrenty.
here is a link to the service bulletin
scroll down about half way down the page
http://x.infinitihelp.com/forum/loca...s.php?catid=84
Originally Posted by Fassster10
i got an 03 and my seat of course started creaking right after the warranty expired, anybody know the link for the DYI, i couldnt find it
As a side note, for those of you with the seatbelt squeaking on the seat, try putting a small piece of felt tape on the bottom of the plastc seatbelt guide where it meets the seat. Its completely out of sight being on the bottom if the guide and stops the squeak. Plus, the entire roll cost me less than $3 at the arts anf crafts store.
