Air Bag Lights Flashing
Old Oct 28, 2007 | 12:14 AM
sushiboiiii's Avatar
So yeah as the thread says sir bag light keeps flashing anyone have any ideaS? starting to really bug me
Old Oct 28, 2007 | 03:35 AM
Beebo's Avatar
do you have warrenty? your airbag is bad and needs to be replaced
Old Oct 28, 2007 | 11:24 AM
k67p67's Avatar
How in the world can you diagnose that by reading the single sentence he posted? Don't tell him to replace the airbag if you haven't a clue why the light is on. It could be as simple as an unplugged harness. OP, read THIS thread and try the reset procedure and see if the SRS light stays on. If so, inspect all harnesses and retry. If it still stays on, take it to the dealer to diagnose.
Old Oct 28, 2007 | 01:01 PM
LjN_728's Avatar
Wait before you go and reset the system, did you recently have anykind of work done near the dash board, center console, radio? If so...then go ahead and reset but if not, I would take it to the dealer and have them run a diagnostic. Resetting the system when there really is a malfunction will cause the airbags not to deploy.
Old Oct 28, 2007 | 02:35 PM
k67p67's Avatar
If the fault still exists after resetting, the SRS light will come back on immediately. If you go through the procedure Riley explains to put it in diagnostic mode, you should be able to determine if a fault exists and what that fault is.
Old Oct 28, 2007 | 02:48 PM
zackt69's Avatar
rarejdm.com
^+1
Old Oct 28, 2007 | 02:50 PM
g35ctuner's Avatar
go crash into a wall, if the bag deploys the system is ok. if not, then take it to the dealer for a diagnose.
Old Oct 28, 2007 | 03:51 PM
Beebo's Avatar
hahahaha...
k67p67 your right I didn’t even think if the OP had any work done on the dash/radio…
Old Oct 28, 2007 | 04:18 PM
ReBirth's Avatar
Do the reset, i had to do the same after i disconnected the sensor on the passenger side
Old Oct 28, 2007 | 04:39 PM
alright thanks guys ill try and reset it i had work done but almost year and a half ago tho but ill try that and see whats up thanks again
Old Oct 28, 2007 | 09:03 PM
accordfreak's Avatar
are you the same sushiboi on hondasociety.com?
Old Oct 30, 2007 | 01:44 AM
yeah =)
Luisgalvan33
Jul 19, 2018 08:16 PM
privatecorye
Steering & Suspension
May 31, 2016 01:56 AM
ghost_g35
Aug 7, 2015 10:31 AM
ZacDesu
Jul 14, 2015 11:13 PM
