does anyone have this problem
Old Nov 3, 2007 | 09:21 PM
fabulustt7's Avatar
when i start my car when its cold and start driving i hear wind coming through the drivers side window but it is all the way up. After the car seems to warm up the noise stops at low speeds but when i do 75+ the wind comes through again? why? and how do i fix this without the dealer, my warrenty is over
Old Nov 3, 2007 | 09:57 PM
d_pak's Avatar
Yes! I live in WI, and have had my G for 3 months now. It's been below 40s at night and the same problem. The rubber hardens and thus the seal is not tight against the window. When it warms up, the rubber softens and seals the door better.
I did a diy fix and it was getting flexible rubber tubing at the hardware store, in my case, I found replacement tubing for wiper wash system, and ran that behind the door seals, specially along the back pillar (near the rear), that gave the door seals enough push to seal better.
During my 1st service last week, inifiniti tech saw what i did and actually replaced it with spacer foam where the tube was runnign along. That seems to work better. Gave me back the tube and said I could add it in as well if it still was a problem.
Nothing is visible from the outside.
I have also heard of silicon treatments that can be applied to rubber seals to help with cold temperature, havent had the need to do that yet.
Old Nov 3, 2007 | 11:29 PM
dan|el's Avatar
i've had the same problem for a while now. i tried a bunch of stuff and went to the dealer, but as of yet no fixes
i also get wind noise coming in from my sunroof. its kinda annoying but thats when the radio comes in handy
if you fix it please post up so i can try to fix mine.
Old Nov 4, 2007 | 02:33 PM
fabulustt7's Avatar
well my 60 thousand service is due in a few weeks so i was going to bring up than
Old Dec 6, 2007 | 06:49 PM
Bob1's Avatar
I have an annoying wind whistle from the passenger window. It almost sounds like the window is cracked open. First trip to the dealer they replaced the window motor. On the way home, same thing. Second trip to the dealer they replaced the window seal, same wind noise heard starting 40MPH or greater, no change.
Went today to the dealer and rode with the service manager. He traced the noise to the little rubber seal on the side view mirror where it meets the window. They ordered one today. I'll update results. In the mean time I'm having my car rebuilt piece by piece.
bananax
Sep 24, 2019 12:24 PM
G35xdriver04
Nov 7, 2015 08:31 PM
itgogitrev
Sep 23, 2015 07:08 PM
mattdg35
Sep 14, 2015 11:28 AM
