How to stop the Brake squealing?!?!
Old Nov 4, 2007 | 09:13 PM
netcbc's Avatar
searched the thread but no clear answer....
I have a 2003 brembo brake system, recently changed brakes to stoptech rotors and oem pads.....
i think after installing the pads it started squealing?
Is project mu b-force the best to stop the squealing or ??
thanks!
Old Nov 4, 2007 | 09:20 PM
Jason@Riverside's Avatar
OEM Pads are dusty and noisy...
B-Force are aggressive pads, will still dust and be noisy...
Hawk HPS are a more Quieter pad compound and less brake dust...
Old Nov 4, 2007 | 09:26 PM
netcbc's Avatar
thanks for the info, i've seen a couple of threads saying they had hawks and they were squealing.....
Old Nov 4, 2007 | 09:56 PM
DrrSeuss's Avatar
yep, I have Hawks all around but only my front passenger ones squeak a little bit.
Old Nov 5, 2007 | 04:10 PM
G35fromPA's Avatar
Did you use enough brake grease in between the pad and shim, and on the back of the shim? The service manual also calls for a bit of grease on the edges of the pads as well.
Old Nov 5, 2007 | 05:00 PM
DrrSeuss's Avatar
I used more than enough grease. I actually took out the passenger ones last week and put on a diff. brake grease on it and it's better but it still squeaks every now and then.
I'm also using 2 shims on each pad, the oem one and the one that came with the Hawk pads...not too sure if it's a bad thing but there's enough grease on them. The driver's side doesn't squeak @ all.
Old Nov 5, 2007 | 07:05 PM
bull3t's Avatar
thanks!
make sure they remembered to put your shims on...
boostelevator
Brakes
Oct 5, 2015 08:56 AM
JoeMac
Sep 28, 2015 12:28 AM
Hawk196
Sep 10, 2015 10:37 AM
NJ6MT
Sep 10, 2015 08:40 AM
3000vr4tt
Sep 7, 2015 12:48 AM
