gas tank problem?
Old Nov 17, 2007 | 03:20 PM
frog's Avatar
gas tank problem?
i know theres a gas tank problem on older models but yesterday after the meet i went to go fill up, after 9-10gals it kept turning off the pump reguardless how long i waited...cupple min tryed..cupple more tryed... it wouldnt it kept turning it off so now instead of a full tank im at 3/4 a lil under anyone have/had this current proble? how did u fix it? is it covered under warranty? i have the 05 coupe, i tryed to look up recalls for my year but i couldnt find any.
Old Nov 17, 2007 | 03:27 PM
Calvin's Avatar
Overglorified Altima
take it to the dealer. it's covered.
Old Nov 17, 2007 | 10:51 PM
Dubfound's Avatar
Its the fuel sending unit! Same **** happen to me.
Old Nov 18, 2007 | 02:27 AM
brooklynite's Avatar
my dealer said nothings wrong with it. they pumped in 12 gals fine. any specific term that i should bring up to them?
Old Nov 18, 2007 | 03:45 AM
frog's Avatar
1 time i put in 20 bucks and hten it started stoping.. yesterday it was 40bucks then it started stopping so i dont know when is the correct way to make it mess up
Old Nov 18, 2007 | 03:47 AM
スカイライン's Avatar
I have 05 coupe and had the same problem off and on for the first 1.5 years.
Dealer first replaced the fuel tanks shutter valve but it did not work, they then replaced the whole fuel tank, but it also failed to correct, so at the end they replaced the fuel sender units and this worked (all under warranty). I don't have the problem anymore.
Fuel sender units replacement work had below parts installed (parts number).
25060-AL51A SENDER UNIT x1
25060-CD00A SENDER UNIT x1
17342-CE800 RINGS x2
Tell your dealer to order these and have them replaced, it will take care of it.
Old Nov 18, 2007 | 11:27 AM
TopTech's Avatar
If it happened only once it sure could have been a faulty pump. I've run into a couple of them before too.
Old Nov 18, 2007 | 06:05 PM
fflores's Avatar
Its happened to me as well... I get to between full and 3/4 of a tank and then it won't let me put any more in
Old Nov 18, 2007 | 06:28 PM
dan|el's Avatar
anybody ever assume that maybe it is just a cheap gas station and a screwed up gas pump/nozzle?
Old Nov 18, 2007 | 06:30 PM
Nism0r's Avatar
thats weird never happed to me
Old Nov 18, 2007 | 08:49 PM
frog's Avatar
i thought it was, i was at a shell a brand new one btw. tryed 1 pump got 20 bucks in it then it started messing up, so i was like humm maybe its the hose.. so i went to a different pump same thing... so i said ill try 1 more diff one, did and it did the same thing. then the most recent one was at a valaro and did it after 40bucks. so i only got 3/4 tank
mtlruss
Dec 20, 2015 01:51 PM
Jnm07
Sep 5, 2015 01:16 AM
Patrick Bovee
Sep 4, 2015 11:57 AM
06gtfanatic
Aug 31, 2015 03:19 PM
Jroc2017
Aug 16, 2015 07:16 PM
