engine noise
Old Nov 26, 2007 | 07:13 PM
1ceman's Avatar
engine noise
everytime i start my car my engine sounds shakey and i checked my engine oil and it is not low or too high...i am using mobile 1 full synthetic 5w30... and also when i drive for a while and stop there is a rumbling noise coming from where my clutch is...does anyone have the same problem?..please help
Old Nov 26, 2007 | 08:57 PM
Beebo's Avatar
Like a grinding noise for a few seconds?
The clutch chatter is normal.
Old Nov 26, 2007 | 09:30 PM
1ceman's Avatar
the engine noise i'm talking about doesn't sound like a grinding noise...it sounds like a shakey noise like the timing belt or something..and it starts making that noise the whole time when the car is running...i also get the grinding noise too when i step on the gas at a low rpm
Old Nov 27, 2007 | 10:57 AM
05GCOUPE6MT's Avatar
The noise you hear when you take off from low RPM is the clutch. This is normal. You have to get used to the car and keep the RPM at a certain range to prevent that noise.
Old Nov 27, 2007 | 11:01 AM
1ceman's Avatar
thanks..i feel better about the clutch...but what about the shakey engine noise that sounds like the timing belt or sumtin..is it normal?
Old Nov 27, 2007 | 11:02 AM
partyman66's Avatar
We have a chain, not a belt. Doesn't sound normal to me because my car doesn't do that.
Old Nov 27, 2007 | 11:41 AM
filthyg35's Avatar
it could be one of the belts not the timing chain...my car was making some shakey noises like you said and when I had the belts replaced, it dissapeared..there are two belts on the car one for the power steering and alternator...the other for the water pump and something else...can't remember....
Old Nov 27, 2007 | 01:29 PM
ISMSOLUTIONS's Avatar
Correction -
1 belt for A/C
1 belt for everything else - serpentine...
rezendvous420
May 31, 2020 01:26 PM
Cskeet
Drivetrain
Dec 3, 2015 09:18 PM
atk08
Jul 30, 2015 03:12 PM
joedaddy1
Jul 28, 2015 02:58 PM
rping
Jul 26, 2015 09:53 PM
