strange noise...
Old Dec 1, 2007 | 12:39 AM
MixturePinoy's Avatar
strange noise...
I just drove home from my inlaws and i began hearing a real horrible noise.. On the highway it sounded like a helicopter was above me. I also feel a vibration on the steering wheel, and when i got into the city i rolled all my windows down and heard the same noise. From what I can tell it's coming from the drivers side wheel well. I looked under there and couldnt see anything wrong... anyone have an idea what this might be? Thanks.
Old Dec 1, 2007 | 02:03 AM
idiosyncratic's Avatar
only thing I could think of is that your inner fender well is rubbing against the tire somewhere?
Old Dec 1, 2007 | 02:08 AM
nope.. everything there is in place... im wondering if it's the something boot..
Old Dec 1, 2007 | 02:56 AM
RaginRaj11's Avatar
You could have a bent rim. I have a similar noise and my steering wheel shakes a little at highway speeds. I hit a pot hole long back causing the rim to bent a little.
Old Dec 1, 2007 | 11:07 AM
I tried letting go of the wheel while driving to see if it veers off to a certain direction, and it doesnt...
Old Dec 1, 2007 | 11:10 AM
G-girl's Avatar
Staff ALUMNI
MP, see if you can get it checked today... I don't like it when I hear noises that aren't supposed to be there coming from my car. I wish I could help. I ran over a clump of duck tape once and it got stuck on my tires, but it didn't make that loud of a noise to where it sounded like a helicopter.
When you find out, let us know what it is.
Old Dec 1, 2007 | 12:15 PM
cungkpham's Avatar
two possible problems:
1) Tires
2) Tires
what you are hearing is "road noise".
sometimes when you drive, and you roll down only one window, you hear it. it DOES sound like a helicopter. BUT when you roll down the other window, the noise decreases. (dont know why, it just does)
Road noise.
Old Dec 1, 2007 | 12:22 PM
Andy2434's Avatar
Tito,
For starters . . . Be sure the lug nuts are tightened properly and that the tire/wheel combo in question is not out of balance. Good luck and be safe.
Old Dec 1, 2007 | 12:45 PM
05GCOUPE6MT's Avatar
See if you got MUD or something in the threads OR rim. This could be messing up the balance causing the car to make that noise & steering wheel to shake. You may also have to take the tire or tire's off to see if something had happened to it. [Tare/RIP/Budge]. It could be allot of things from a messed up rim to the suspension. Unfortunately you are limited to what you can self diagnose without being a mechanic. I would take each wheel off and look at it and the suspension to see if anything sticks out. Did you hit a pothole?. The colder whether makes it easer to cause damage to rims and tires on lowered cars or cars with sport suspensions/packages.
Old Dec 1, 2007 | 12:46 PM
MIA BlazinVQ's Avatar
brb getting cut
it sounds like if you had a flat. check to see if your tire pressure is up to spec, it could be really low.
Old Dec 1, 2007 | 02:16 PM
ON's Avatar
ON
Originally Posted by andy2434
Tito,
+1 Check your lugs. It's probably loose and commonly overlooked.
Old Dec 1, 2007 | 03:50 PM
daveblank's Avatar
It could be a belt separation in the tire.
Old Dec 1, 2007 | 04:12 PM
holy shlt... Yume and Andy, you are right.... i changed out my brake pads the other day, and my stupid *** didnt tighten the lugs on the drivers side... I just tightend all around to make sure everything was torqued properly... 2 out of 5 lugs on the driver side were almost off... should i be worried about alignment or anything now? Thanks... stupid stupid tito...........
Old Dec 2, 2007 | 02:11 PM
G-girl's Avatar
Staff ALUMNI
Oh dude! that's scary! glad you got that fixed.
Old Dec 2, 2007 | 11:49 PM
cungkpham's Avatar
i stand corrected...
