Power window problem
Old Dec 6, 2007 | 10:15 AM
Loe G35's Avatar
Drivers side (yes I searched but my problem is slightly different)
Auto down works fine
Auto up, it only goes up probably an inch and falls back down, But the window will roll up if not using the auto function or when I roll up the window w/o auto function about an inch and then fully engage auto function. (basically a slow trigger of the switch vs. a fast trigger).
Do you guys think it needs a re-set? No strange noises (yet), the speed of the power window is still good.
Old Dec 6, 2007 | 10:27 AM
Infin80's Avatar
It might just be something as simple as your motor needing to be replaced.
Old Dec 6, 2007 | 10:33 AM
Hi-TechG35's Avatar
^Motor needs replacing. Take it to the dealer if you are under warranty and they should fix it free of charge. I had the same problem a few months ago. I would hold the up button switch and it would go up. Then I put my window down one day and it didnt want to go up. I banged the door panel and that got it up. I finally stopped being lazy and got it fixed under warranty.
Old Dec 6, 2007 | 10:53 AM
Loe G35's Avatar
I'm still under warranty until the end of this month for basic bumper-to-bumper. I'll have to bring it in. Thanks guys!
mike730
Jan 12, 2018 04:25 PM
leo38cheng
Nov 12, 2015 06:49 PM
will091195
Jul 27, 2015 09:19 PM
apintojr
Jul 23, 2015 10:52 AM
