Noise from sunroof?
Old Mar 17, 2004 | 10:21 PM
dominoedge's Avatar
Noise from sunroof?
I've begun hearing a slightly strange noise in my car. It's not very loud, but it sounds like it's coming from the sunroof ???? When I have the sunroof closed all the way (both glass and slider are closed) then there's no noise. When the slider is open, there's a soft creaking sound.... especially when I go over a bump or something.
.... anyone else have this or heard this?
thanks
04 G35 Coupe 5AT / Twilight Blue / Aero kit / Nav / Wheels
Old Mar 18, 2004 | 12:30 AM
clm288's Avatar
Re: Noise from sunroof?
Yep, the dealer has already worked on mine 2 times. There is a bulletin on it. Take it in and have them do the service bulletin, they can't 100% fix it, but can definitely minimize. I had problems with my window making popping noises also. Had that worked on 4 times, finally got it somewhat fixed. Good luck.
Old Mar 18, 2004 | 07:26 AM
Max929's Avatar
When I took my car in for the 3750, I had them check the sunroof too. When closed it was fine, but when open it would sometimes/not often rattle over a large bump. They said the fixed some clips inside it. It seems to have done the trick.
Also, I did have an occasional popping sound from the driver window. It seemed to only happen while the window was fully closed. That sound however, went away after I had the car in the body shop last fall because of a deerstrike. They had to replace the driver side glass and since they did that, the popping sound hasn't happened. So there had to be something off in there somewhere.
Definitely point things out to the dealer because, for me, the they have always been very good about nailing these things.
'03.5 Silver/Willow Coupe, 6MT, Prem, Nav, 4-Piece Aero Kit
Dallsinghjr1
Sep 17, 2023 11:25 AM
Marlin84
Apr 1, 2020 12:52 PM
THMotorsports
Suspension-Vendor
257
Dec 18, 2018 05:43 PM
dcsbh1
Oct 1, 2015 03:15 PM
alinero718
Sep 27, 2015 09:35 PM
