Rear valence and third brake light removal question, coupe
Mar 19, 2004 | 05:30 PM
I was just wondering if anyone had removal instructions of the thrid brake light and rear valence piece. I am adding a spoiler to my coupe and wanted to remove the thrid brake light since the one on the spoiler would replace that. After removing the third brake light I am aware that there will be a hole in my rear valence piece and would like to remove that piece also to have it reupholstered to cover up the hole. Just wondering if anyone has done this and has any instructions or tips for me.
Thanks in advance
Reply 0
Mar 19, 2004 | 06:01 PM
Re: Rear valence and third brake light removal question, coupe
You can take it out in under a minute. The whole unit comes out. Clime into you back seat and just squeeze the outer edges in a little and gently pull light back toward the front of the car. It should pop right out. Next unplug the wire from the little plastic connector. That's it. I decided to leave my light in place but unconnected so it wouldn't come on. If you decide to take the light out you'll have four small rectangular holes. Hope this helps.
2004 G35 Coupe 5AT Diamond Graphite / Graphite
Performance | Premium | Aero | Clear Bra | Zaino!
Reply 0
