Issues..
Old Feb 21, 2008 | 02:56 PM
JOKER's Avatar
CLUB MODERATOR
Originally Posted by Mixturepinoy
Done.. but i don't think i did it properly... this sucks.. i might have to call in re-enforcements... Jeff, is your OBDII gadget sophisticated enough to reset my throttle managment?
Try the battery dude.
Take it off tonight and connect it back on tomorrow morning.
If you get same **** then plenum is deff leaking.
Old Feb 21, 2008 | 02:57 PM
MixturePinoy's Avatar
Joker.. did you disconnect your throttle body when you installed your plenum? Or did you leave it connected? I may go ahead and go with the liquid stuff.. I just hate the sticky crap..
Old Feb 21, 2008 | 02:58 PM
Jeff92se's Avatar
Red Card Crew
Actually the 2 gasket thing is what was recommended by Crawford.
Tito. Yeah my Autoengunity IS supposed to be able to do the idle resets etc.. I haven't personally tried it though.
Old Feb 21, 2008 | 02:59 PM
JOKER's Avatar
CLUB MODERATOR
I disconnected the wire harness but I did not unbolt the thing from plenum.
Old Feb 21, 2008 | 03:02 PM
Yea, this is an old style plenum, which requires 2.. but i have 3 now
Jeff, how about we experiment and learn how to use that thing ?
Old Feb 21, 2008 | 03:04 PM
Jeff92se's Avatar
Red Card Crew
If I have time, I'll fire it up and see how easy it is to do.
Old Feb 21, 2008 | 03:06 PM
Cool. I'm going to try to reset it again tonight, both stupid pedal way and battery way.. i'm not sure the battery dx will reset my throttle though..
JOKER's Avatar
CLUB MODERATOR
hahahahhaa
You deff leaking man.
Old Feb 21, 2008 | 03:07 PM
JOKER's Avatar
CLUB MODERATOR
It will reset the ECU
and when you fire it up after the reset, throttle will be adjusted by newly reset ECU
Old Feb 21, 2008 | 03:09 PM
I hope so... this nasty breathing is pissing me off
Old Feb 21, 2008 | 03:13 PM
JOKER's Avatar
CLUB MODERATOR
you got to get rid of the gaskets man.
I would use one with liquid gasket on both sides of it.
They suggest to use two gaskets prolly cuz of the length of the bolts or something.
Cuz with a spacer you get a gasket on both sides of the spacer. So with a plenum you prolly get same length bolts as with a spacer and that is why they suggest two gaskets.
I don't see another reason why would the suggest two gaskets.
Old Feb 21, 2008 | 03:15 PM
Jeff92se's Avatar
Red Card Crew
Actually Crawford stacked as many as 12 gaskets to make their own ghetto spacer at one time. But it wouldn't hurt to use some gasket sealer.
Old Feb 21, 2008 | 04:26 PM
I'm pretty sure I was leaking at the 2 long center bolts.. that plastic washer was bent due to me over torquing it. so i placed a metal washer on top of that...
Old Feb 21, 2008 | 04:29 PM
JOKER's Avatar
CLUB MODERATOR
with 3 gaskets.
I guarantee you it leaks even worse.
Old Feb 21, 2008 | 04:33 PM
  #30
Jeff92se's Avatar
Red Card Crew
The center bolt leak should be very easy. Just need two more nylon washers. Available probably anywhere.
