Issues..
Old Feb 25, 2008 | 02:02 PM
  #46
MixturePinoy's Avatar
Originally Posted by Jeff92se
atf for auto Nissans = Nissan's auto tranny fluid aka J-Matic
ahh ok. yeah, exactly what i mean.. I heard I need like 10 quarts or something?
Old Feb 25, 2008 | 02:06 PM
  #47
Jeff92se's Avatar
Red Card Crew
total capacity is like 10 qts or so. But the replacement depends on what you are doing. A simple drain/flush is approx 4-5 qts or so. So if I do it, I plan on drain/fill every 15-20k or so. You won't get 10 qts out unless you remove the valve body at least.
BTW do you have your level stick included w/ your car? I only have a stupid cap
Old Feb 25, 2008 | 02:16 PM
  #48
I think i just seen a cap as well
Old Feb 25, 2008 | 02:18 PM
  #49
Jeff92se's Avatar
Red Card Crew
Sucks. I hear you can order the whole dipstick from a dealer. If you don't have this, then you need to carefully measure what comes out and replace the exact amount back. Assuming the original amount is right
Old Feb 25, 2008 | 02:21 PM
  #50
I'll call up Drewer, I'm sure he's already done this, he's at over 100k and does all his maintance. He may have a dipstick already that he wouldnt mind lending
Old Feb 25, 2008 | 03:34 PM
  #51
mediumred91lx's Avatar
if you let it drain until it no longer drips, 3 1/2 to 4 qts. only if you plan on pulling the trans and torque converter out will you need 10qts, and only a few of the 03s didn't come with dipsticks. pull out the 10mm and make sure you have a dipstick.
Old Feb 25, 2008 | 03:55 PM
  #52
Cool medium. i'll check that out today. I take it you've done this already? IF so, where did you get your fluids?
Old Feb 26, 2008 | 12:09 PM
  #53
car seems to have learned itself after battery reset.
Old Feb 26, 2008 | 12:26 PM
  #54
Once or twice.. i work on these cars.
Joshua615
Aug 31, 2015 12:29 AM
vat55
20 Inch
May 1, 2015 11:47 PM
alfhasg35
Sep 22, 2014 06:59 PM
DigitalMaxz
Canada
May 29, 2014 09:56 AM
Kyle Barbaro
Lighting
Mar 24, 2013 04:56 PM
