Courtesy / Step Light LED..PLEASE HELP!!
Old Feb 21, 2013 | 06:36 PM
Kyle Barbaro's Avatar
Angry Courtesy / Step Light LED..PLEASE HELP!!
ok so after asking the dealership to help me out with my step light LEDS, they quoted me $300!!!! to change out the freakin bulb!!!! In frustration I came home and just decided to do them myself. I popped off the lens and took the old bulb out. I had my new LED working for a couple seconds and when I went to pop the lens back in it cut out. After my hands freezing up I decided to give up and come here for help because I cant seem to get it to turn back on. The harness appears to be connected as I never disconnected it and was able to get the bulb in and out with no issues.. ive looked online and through the forums for a DIY but couldnt find anything.. any help would be appreciated..05 Coupe..
Old Feb 21, 2013 | 08:07 PM
krewboy's Avatar
The only thing you can really do it play around with it. When I was installing all of my led's I had to play around with them a little bit, making minor adjustments before i got them all to work properly. I mean you only tried once...
Also make sure its the correct light. https://g35driver.com/forums/lightin...ent-guide.html
Old Feb 21, 2013 | 08:31 PM
CodeR3d's Avatar
I had issues installing leds there too. I had to play with them A LOT to get it to work. The base on each side of these lights is a bit thicker than the oem lights. Try inserting it at different angles or reversing it and also try using the other bulb since you should have a set of two. Also you might just put the oem bulb back in for a second just to make sure nothing got disconnected or there is no other issue. Make sure its making contact though because the ends will be wider now because of you trying to get the leds in there. Leds seem to be VERY picky in that area.
Old Feb 21, 2013 | 10:47 PM
alright thanks for the advice, ill have to give it another shot over the weekend. Im still shocked they wanted 300$. Friggen tech was like yeah its about an hour and a half each side. I guess I understand the meaning of stealership now.
Old Feb 22, 2013 | 12:19 AM
guitarrocker98's Avatar
I have the exact same issue. I bought the car that way and after reading this I realize it could be my bulbs... I'm going to pick up OEM ones to check it out.
Old Mar 13, 2013 | 08:06 PM
Saboture's Avatar
I just replace those bulbs 15 minutes ago with these.
Classy Autos 31mm Festoon 12 LEDs SMD LED Bulb BRILLANT RED (A PAIR) DE3022 DE3175 by CLASSY AUTOS : Amazon.com : Automotive Classy Autos 31mm Festoon 12 LEDs SMD LED Bulb BRILLANT RED (A PAIR) DE3022 DE3175 by CLASSY AUTOS : Amazon.com : Automotive
You really have to force them into the socket on both sides otherwise it sit correctly. Make sure the LED's are facing down when you install them as well.
Old Mar 24, 2013 | 04:56 PM
GBoss's Avatar
I dunno if you are still having probs or not but what i did was clamp down the the metal holders on both sides until they were almost flat, then put the bulb in. You will have to force it in but the clamps will naturally secure it down and hold the bulb in place.
mtlruss
Dec 20, 2015 01:51 PM
RAVSPEC
Wheels & Tires-Vendor
Aug 21, 2015 06:03 PM
Tukeeg35
Engine - Electrical
Aug 19, 2015 02:08 PM
