When i start up car i get ticking sounds?
Old Mar 7, 2008 | 06:36 PM
specialist's Avatar
Angry When i start up car i get ticking sounds?
2003 g35 basically stock.
I get ticking noises sound like it valves are hitting? any one have this problem? Does not sound healthy!!!
Old Mar 7, 2008 | 06:37 PM
BlueDevilBAMF's Avatar
Happens to me on occasion... probably valve tap.
Old Mar 7, 2008 | 08:31 PM
LightsOut's Avatar
SIETESG
mine does to. i thought it was it was from low oil, checked but it was full.
i just ignore it, i dont hear it all the time. my previous car made the same sound. the sound came from the fuel injectors, But it was normal.
Old Mar 7, 2008 | 10:53 PM
specialist's Avatar
that really sucks
Old Mar 7, 2008 | 10:59 PM
speedracerg35's Avatar
are you using an oil filter with a check-valve to keep the oil in the upper part of the engine and not drain into the oil pan?
Old Mar 7, 2008 | 11:04 PM
Andy2434's Avatar
Have you checked the engine oil level? If not, check the said when the engine is cold and see if the oil level is up to par.
Old Mar 8, 2008 | 02:50 PM
htownboy's Avatar
My friends 05G couple was ticking for just a few seconds at startup each morning even though she changed oil on time always... I had her switch to Royal Purple one year ago and the ticking stopped and has never returned after 25,000 miles.
It's all about how well you want to treat your G... She also said it became "peppier" and "burns less fuel" since the change.
Old Mar 8, 2008 | 03:28 PM
Algy's Avatar
my dad owns a auto shop and people always come in about problems like this. He told me that it could be your spark plugs of your spark plug wires.
Old Mar 8, 2008 | 04:38 PM
officerdbag's Avatar
I get an occasional tick---------tick----------tick when i turn the car off from a long drive, or if I'm stopped at a light after a while of driving. I don't really worry because I've heard that sound from almost every car I've owned.
Old Mar 8, 2008 | 11:32 PM
specialist's Avatar
i am using moile 1 full syntheic wiht stock filter
Old Mar 9, 2008 | 12:44 PM
Andy2434's Avatar
That is normal. You are hearing the hot metal components underneath the car contracting and cooling down. However, the OP may have a different issue.
If the OP is experiencing engine valve train noises, it is definitely worth his/her time to look into it.
Old Mar 9, 2008 | 02:42 PM
htownboy's Avatar
This is normal...
The noise that started this thread was heard at startup so it's a different thing...
chinee
Jun 10, 2024 07:48 PM
Sepsis
Feb 12, 2020 02:05 PM
ghost_g35
Aug 7, 2015 10:31 AM
BlackGee35
Jul 21, 2015 07:24 PM
realtalk21
Jul 20, 2015 09:07 AM
