Intelligent Key Stuck!
Old Mar 15, 2008 | 12:33 PM
msilverton's Avatar
To have a second key for my wife I purchased a key blank and an Intelligent Key fob from two different sellers on eBay.
They arrived and each was as advertised. I have to drive 2 hours to the closest dealer to have the key and Intelligent key fob programmed. So as not to lose the two items I put the key blank in the Intelligent Key.
Now it won't come out! Is there a trick, is it specifc to these two? I am hooped?
Thanks for any advice.
Mike
Old Mar 16, 2008 | 03:33 PM
ballain's Avatar
theres a latch inside holding the key, if you look on the back of the FOB
you should see a sliding button, if you slide that all the way,
you SHOULD be able to take it out,
now im not saying its not possible that its stuck inside.
hope this helps
Dallsinghjr1
Sep 17, 2023 11:25 AM
G35xdriver04
Nov 7, 2015 08:31 PM
