problem with my damn hood!!!!
hey has anyone ever had this crazy prob with there hood, it keeps catching on my fender on the drivers side when i lift it up, do you think i just need to unbolt it and pull the hood out just a little bit, or maybe redjust the fender alil. any and all help would be appreciated. thanks guys.
get a friend to help you hold the hood while you loosen the bolts on the side that the hood is hitting the fender. have your friend tug, pull, adjust it, etc. then you tighten the bolts back up and you're good.
no noone hit me but i was just wondering cuz its like its barely catching on the edge of the fender by the window so yeah i guess ill try what "orly" said. thanks alot guys i really needed that help.
I have the same exact problem. I was at the dealership monday to get a state inspection, head light recall, and service done. I mentioned the problem with the hood and its being fixed under warranty and they sent it out to a body shop to repaint the affected area. They still have my car and i still have their loaner.
My car is a 2003 and it is now 2008. Will this be covered still under warranty or am I screwed?
I had this problem with my 04. it was catching the corner of the passenger side fender when i opened it. I just started to pull the hood towards me then lift upward and it cleared it.
Now it doesn't do it anymore. this might work as a temp fix if it's not catching a huge part of the fender.
magnetism80
Feb 1, 2019 10:00 AM
