Reverse to Drive Clunk...
Old Apr 6, 2004 | 04:25 PM
ozracer01's Avatar
I just noticed something the other day, When I was reversing out of my garage, and when putting the car into Drive, it makes a loud CLUNK sound. I was thinking maybe i put the gear in too fast and I didn't give the tranny enough time to engage, so I just sat there and kept going from D to R and vice versa, and each time it made the clunk sound. I'm setting an appt with Infiniti to check this out. Anybody else have this problem?
04 DG Coupe, Prem Package, 18's, Aero, Z tube, K&N drop in filter, 5-wire Grounding Kit
Old Apr 6, 2004 | 04:30 PM
sixone's Avatar
Re: Reverse to Drive Clunk...
I have an 03 coupe and have the same issue (don't think its a problem). If you sit still enough and look out your window at your hood you can actually see the whole car shift along with the clunk. I think its normal, but if otherwise please PM me and let me know so I too can get this checked out.
OG 03.5
Old Apr 6, 2004 | 04:37 PM
GXXXV's Avatar
That sound is coming from your brakes and it is normal. No need to worry.
Old Apr 6, 2004 | 07:15 PM
ozracer01's Avatar
No its not the brakes, Because i know what that sound is, its the ABS modulator self-test. This noise comes from, it sounds like the driveshaft, but i'm not entirely sure.
Old Apr 6, 2004 | 11:15 PM
GR8TG35's Avatar
I posted the same question a few days back...
I noticed the same thing with my auto trans...
after a good hard or long ride...when comming to a standing stop and shifting into reverse, there is a loud clunk from what sounds to me the rear universal joint or the yoke on the rear end....
If you let the car idle for a few minutes or shut the car off...when you restart it a few minutes later it does not do it any longer...
I figured it was the result of pressure in the valve body on the trans which cause a hard shift at idle....
I took my car in for an oil change, but since it doesn't do this constantly I figured I give it some time and see what happens...really annoying though...
let me know if you get any results from your dealer...Maybe there a TSB out on this issue...thanks
</font color=blue>2old4this</font color=blue>
04 cpe IP/willow/5at/prem/18's/JDM clear corners/Piaa's/MTEC H4 Super White fog/highs
bu villain
Accessories
63
Aug 25, 2016 07:14 PM
Calvin
Southern California
12
Oct 15, 2015 04:21 PM
Kng0fHrts
Sep 15, 2015 05:40 PM
ghost_g35
Aug 7, 2015 10:31 AM
