Help! Changing oil but oil plug screw keeps spinning!
Old Apr 20, 2008 | 12:22 AM
bigkrnxboi's Avatar
I just changed my oil, but it seems as if the oil plug keeps on rotating even if i try to unscrew it or screw it. I know i didnt strip the bolt. Is there any way i can get it out?
Old Apr 20, 2008 | 12:34 AM
Ralph0064's Avatar
thats sucks man! you gonna have to replace the oil pan. Re-tapping the pan is only a temporary fix and will eventually end up leaking. GL...
Old Apr 20, 2008 | 12:42 AM
bigkrnxboi's Avatar
i know why its turning and its because i forgot to put the washer on the bolt. Is there an easy solution to taking it out?
Old Apr 20, 2008 | 02:26 AM
partyman66's Avatar
The washer has nothing to do with the plug screwing in or unscrewing... you either stripped the threads on your oil pan, or the socket you are using on your ratchet is stripped and it's just spinning around the head of the drain plug. 12-point sockets are easy to strip(if that's what you're using), and you might just have an old socket that doesn't bite that good anymore.
The only other thing I can think of is that someone else put a smaller drain plug in your car, but if that was the case.. you would be leaking oil all over the place and your motor would probably be seized by now.
Old Apr 20, 2008 | 09:53 AM
superchargedg's Avatar
Call napa and get a +1 oversize drain bolt or do it right and get a new oil pan.The oil pan is easy to replace but a pita to get off but since you are putting on a new pan go ahead and bent the old pan getting it off.
Old Apr 20, 2008 | 10:08 AM
express705's Avatar
replace the pan. its quick and easy.
Old Apr 20, 2008 | 12:45 PM
bigkrnxboi's Avatar
how much would it cost to replace an aps oil pan?
Old Apr 20, 2008 | 02:30 PM
ffaattccaatt2's Avatar
damn that sucks, happened to me one time at this shop i was working at, screwing it on and it never got tight at all, i was like wtf...i think it was because they went to those easy lube places, they always tighten that thing way to tight. so i had to get a +1 overside, drill it out, re-tap it, and that was that. never had a problem with it since(or atleast customer never noticed)
Old Apr 20, 2008 | 02:53 PM
Mr.GEE's Avatar
20 Year Member
Use a thin blade screw driver and lightly pry under the bolt head while unscrewing the bolt with a wrench. In most cases the nut in the oil pan is hardened steel and the softer steel drain plug is what gets stripped. If you are successful in removing the drain plug, inspect the threads in the pan and chase the thread with a tap coated with grease, so any burs stick to the grease rather than find themselves in the oil pan.
Old Apr 21, 2008 | 11:33 PM
6mt-driver's Avatar
Same thing happened on my last car--took it to a chain for an oil change and the next shop I went to said the bolt rotates and won't come out, but no oil was leaking. They wrote me up a $1000 estimate for throwing in a new pan. I left there thinking that's what I might need, but I took it back to the place that f'd it up and they somehow removed the bolt and put in new one in. I think it's designed so that the bolt strips before the threaded insert in the oil pan does, but I'm not sure. Before I got it fixed I picked up a self-tapping tapered bolt from NAPA for $3.50, so that if the oil pan threads were stripped this slightly larger bolt would re-tap the hole as it went in. But it turns out I didn't need to use it. Might want to have one of those on hand, in addition to the regular bolt, when you get the stripped bolt out. I assume they took a pair of pliers and pulled and turned it to remove it, as opposed to drilling it out which would get metal shavings in the engine.
Old Apr 22, 2008 | 11:31 AM
Dubfound's Avatar
Happen to my R32 and cost $267 for a new oil pan
Frostbite91
Aug 20, 2015 07:20 PM
yassy
Aug 9, 2015 07:31 PM
ghost_g35
Aug 7, 2015 10:31 AM
TWASkyliner
Aug 1, 2015 11:43 AM
justgotg35
Jul 19, 2015 12:33 PM
