problem when putting gas on.....
Old Apr 24, 2008 | 10:45 PM
ilbambino86's Avatar
Angry problem when putting gas on.....
yes i have been having problems when i gas my car at the gas station..... i hope i dont get flamed, i did my research but couldnt find an answer.... so every time i put 93 oct. after like 20 secs of putting gas, it always stop and i have to squeeze 20 times to get half a tank.... so after a while it gets so fvcking anoying.... just wondering what to do??? some one else having these problem???
Old Apr 24, 2008 | 10:54 PM
jinubob81's Avatar
Evil Bastard
there should be a tsb (which my dealership has refused to perform) on the filler neck or something or other.
they've just exchanged the fuel sender or even the gauge itself.
apparently, it's a pain in the **** to do. I dunno. I can get mine to fill up to about 15-16 gallons, which leaves me at about a bar away from full. Annoying, but not that terrible.
Old Apr 24, 2008 | 10:58 PM
thanks bro, ill check on that..... any other opinions, suggestions????
Old Apr 25, 2008 | 06:49 AM
blackstorm's Avatar
i used to have that problem with my old BMW, idk what it was but i kno that most of the time if i turned the pump sideways and hold it there while i was pumping it, it would go away and i could fill up without stopping, not sure if it would deff work for you but you can give it a shot!
Old Apr 25, 2008 | 07:33 AM
breftayka's Avatar
Dont put the nozzle all the way into your tank... Put it half to 3/4 of the way in there...
Old Apr 25, 2008 | 06:46 PM
Nin's Avatar
Nin
there's a TSB on it
you can pump gas at half throttle and it'll go in fine...just takes longer to do.
mine did this for the first time that i ever filled it up. after i pumped it full at half throttle, i guess having the full tank fixed something or relubricated the one way flap thingamabobber inside so it doesn't get stuck now and fills up all the way ($86 to fill it the other day lol)
Old Apr 25, 2008 | 06:52 PM
Mike_Deezy's Avatar
+1 I have the same problem on and off and this works for me.
Old Apr 25, 2008 | 07:06 PM
BlueDevilBAMF's Avatar
Supposedly pumping at half throttle is better anyway... Full throttle might not be an accurate gallon reading because of air coming in with the gas. But, you still get charged the same.
Since I've started pumping half throttle I've noticed at least a 1mpg improvement per tank.
chinee
Jun 10, 2024 07:48 PM
Cskeet
Drivetrain
Dec 3, 2015 09:18 PM
attarday
Jul 15, 2015 04:03 PM
Jadenkid22
Jul 14, 2015 12:33 AM
