Got a leak? need help..
Old May 7, 2008 | 05:54 AM
emorehs's Avatar
Hey guys im newbies on this forum.. and im goin to need your help..
I got 03 coupe and had a 58K on it.. the problem is everytime a start my engine i get a leak under the engine.. I went two different body shop the first one they change my oil filter pressure, but the leak stop for only 3 days.. Then i went to the other one they said my car is fine they don't see any leak.. so i noticed that I only get a leak when i start my engine....(and i check the oil stick before i start the car "theres C and H" the oil is in the middle already)
any ideas?? pls pls
thanks..
Old May 7, 2008 | 01:26 PM
sliderg35's Avatar
If you went to a body shop for an engine problem, you're in big trouble already!
Check your oil filter yourself. When you get under there, you may see where the oil is coming from (assuming it is oil you are talking about).
Old May 7, 2008 | 01:46 PM
falconey's Avatar
Check it him/herself? Based on the post I don't think this is going to happen. I hate to say it, but with what seems like a lack of automotive knowledge you might want to just take your car in to the dealer.
Old May 7, 2008 | 02:00 PM
dc78chs's Avatar
^^^^ +1
Old May 7, 2008 | 02:02 PM
Mike_Deezy's Avatar
What's leaking? Is your A/C runnning?
Old May 7, 2008 | 03:15 PM
grazsrootz's Avatar
what kind of fluid is leaking???? if its oil, definately check the filter and the drain. for some reason, correct me if im wrong, but isnt the oil pressure pretty high on start up to get the oil flowing? your best bet is take it to a mechanic, or even a jiffy lube or lube works and ask where they think the oil is coming from
Old May 7, 2008 | 03:25 PM
Mike_Deezy's Avatar
Stay Away From Jiffy Lube!!!!!
Old May 7, 2008 | 11:41 PM
duger00's Avatar
If you noticed this after a recent oil change, could be from left over spillage of oil. Take it to any automotive repair shop, and they should be able to find a leak, wehter its the oil pan gasket, oil filter seal, other misc., seals. This is oil we are taking about right.
Old May 8, 2008 | 06:46 PM
emorehs's Avatar
Thanks for some helps guys/girls.. and yeah its an oil leak were talking about in here. I check it on myself falcony and i saw the leak came from the hose that connect the oil filter presure. But after they change my Oil filter presure i don't see any leaks from that hose anymore.. so im just wondering now where the hell the leak coming from when i start my engine???? so yeah.... im goin to change my oil by next week so im just ganna probably drain it totally.. then change my filter then i'll update you guys...
--any suggestion about what filter im goin to use???--
thanks a lot....
RemmyZero
V36 DIY
Apr 23, 2018 11:13 AM
KallDay86
Jan 8, 2016 12:42 AM
hrdwirk1
Oct 2, 2015 06:34 PM
NyCrAzY
Oct 1, 2015 09:19 AM
vamarris
Sep 26, 2015 12:56 PM
