Weird noise between shifts...
Old May 21, 2008 | 10:52 AM
1180G35black's Avatar
I have that same sound in my 05 I was worried about it. But it seems like I am not the only one so thats a little better. I will be taking it in to the dealer tho
Old May 29, 2008 | 12:42 AM
Waramp's Avatar
Update: the tech took it for a drive with me and said it was louder than what he has heard in the past. They are replacing my flywheel under warranty and asked me if i wanted to buy a clutch since everything has to come apart anyway. Is it worth upgrading to a nismo clutch?
Old May 29, 2008 | 02:45 AM
Skaterbasist's Avatar
Retired SuperMod
It's the throw out bearing. I got this all the time...not sure if I still have it since I haven't payed attention to it, or got use to it.
Old May 29, 2008 | 07:59 AM
GR8TG35's Avatar
^ +1
What he said. If your at a stop idling, and you push in the clutch, you should/will hear a low pitch growl. If that's the case, its the throw out bearing. That is the weakest link in a manual trans set up.
Don't know how many I replaced over the years in all my manual cars......
Trick is, do not ride the clutch pedal.....this puts a small amount of pressure on the throw out bearing, and in time will dry it out causing the whinning/growl you are hearing now.
Good luck
Marlin84
Apr 1, 2020 12:52 PM
THMotorsports
Suspension-Vendor
257
Dec 18, 2018 05:43 PM
RichardP9
Drivetrain
Oct 26, 2015 11:25 PM
dcsbh1
Oct 1, 2015 03:15 PM
alinero718
Sep 27, 2015 09:35 PM
