Questions about Est HP Improve on APS Single Turbo
Old May 10, 2008 | 11:46 AM
jbk1818's Avatar
Just had a APS Single Turbo installed on my 04 AT
Base lined @ 240/240
Added APS single Motordyne spacer and Magnaflow Cat back
Results 293/393
WTF
any thoughts
Iam thinking Waste gate leeking down and not holding boost
or is the Turbo to small and not "blowing "enough
was seeking
375 / 380
B
Old May 10, 2008 | 05:38 PM
releasedtruth's Avatar
375 sounds like it might be a bit high, but maybe you could give us a little more information, boost level, details of your setup, installation, tuning, all that. I'm sure you can get more out of it.
Old May 10, 2008 | 07:05 PM
jbk1818's Avatar
tuning Day 2
day 2 results
335/457(?)
more facts
Tuner reran today as per below
Tested in CA (91 octane)
1 other thing changed rubber tot potenza's 255/35/18 on back....
Hello Bradley,
Nothing was changed on the map, still 9 psi tapering to 3 psi. However, I got here at the crack of dawn to make the run in 51 degree with 69% humidity (foggy)! I told you the "Power of Air Density" really matters ;-) ! There will be a very interesting Article on our website in the next 2 or so weeks called "The Power of Air Density". There will be at least 15 dyno charts that show the same as yours..
We recommend for future upgrades on your G:
1. Aquamist HFS-5 Methanol/H20 kit
2. APS Tial external wastegate set up with down pipe.
APS has not got back to me yet. I will let you know when they do.
Are you picking up the G tomorrow? What time? I will call Ryan and let him know. I already road tested your car and it is great. Keep in mind above 5000 rpm you are running a little bit rich but it is very safe. If you do the Methanol with WG upgrade then we will produce more WHP and then we can lean it out a little bit.
Again any further thoughts
noctilucous
2nd Gen (V36) Sedan
Aug 6, 2015 08:47 PM
G35Sask
Intake & Exhaust
16
Aug 5, 2015 10:17 PM
RA102223
Intake & Exhaust
Jul 25, 2015 01:03 PM
Chattzx
Jul 17, 2015 11:23 AM
mushu
Jul 15, 2015 03:55 PM
