NEED HELP! Broken AC...
Old May 11, 2008 | 08:13 PM
Kenrik's Avatar
Ok so I was driving today and it was really hot out (96 Degrees) and my AC stopped working.
I smelled something that smelled like Latex paint.
Well I got a refill kit with gauge and filled her up to the proper PSI... it did not get cold.
I checked it 10 Minutes later and it was empty.
I filled it again and waited... then I turned on the AC and guess what.. all of the refrigerant came out of the vents in a big puff.. I could hear the hissing from the leak.
So... is it the evaporator core? a blown O-Ring? What?
I need help it's hot as hell here.
Old May 11, 2008 | 08:35 PM
badtziscool's Avatar
Sounds like something on the low pressure side. I wouldn't think it's your evaporator or the lines going to it, since it would be pretty hard for those components to fail. I'd say most likely its a plastic or rubber seal.
Regardless though, that's going to be a pretty tough fix. I guess your warranty is out on the car?
Old May 12, 2008 | 12:49 PM
Drox's Avatar
Do you have an intake? Reason I ask: https://g35driver.com/forums/intake-exhaust/90906-installed-jwt-pop-charger-protect-move-ac-line.html
magnetism80
Feb 1, 2019 10:00 AM
jeffbdye
Jun 1, 2018 03:51 PM
itgogitrev
Sep 23, 2015 07:08 PM
