Differential / Coolant Fluids
Old May 13, 2008 | 10:21 AM
CalgaryG's Avatar
When I went to Mr. Lube the other day to get my oil changed, they said that my rear differential/coolant fluids should be flushed or what not. They quoted me about $90 (CAD) each.
How often do you guys get these done? My car is an '05 with 24,000 miles.
Also, at what point do brakes/rotors normally need to be replaced? (How can I tell if they are getting old?)
Old May 13, 2008 | 10:56 AM
Swivel's Avatar
Moderator
All those intervals are in your manual, or you can search and likely find them here on the site. 20 bucks worth of gear lube and half an hour of your time would get you a better job than Mr. Lube, I'm sure. They'll tell you anything to get your money.
Rotors should be measured with a micrometer and compared to the minimum recommended thickness. At 24k you are *probably* good.
Be sure to sign up in the Western Canada registry and think about coming to the June 7 meet in Sylvan Lake!
https://g35driver.com/forums/showthr...=145361&page=7
Old May 13, 2008 | 12:04 PM
TurK's Avatar
^+1
You dont even have to do all that untill 30,000 miles...and come on dude, quick lube? are you serious. Do it your self, make sure it gets done right.
Old May 13, 2008 | 12:09 PM
Artifice's Avatar
Coolant is simple and so is diff fluid... It is a simple DIY. Change your Diff Fluid if you are being super hard on your car and drift every corner! Otherwise if you are a "normal" driver you have nothing to worry about.
Old May 13, 2008 | 12:12 PM
InTgr8r's Avatar
Staff ALUMNI (retired)
I'd highly recommend a diff fluid change.
I did one after ~10K & got a big plug of grey goop on the magnetic drain plug.
After that follow the interval in the manual.
If you're going to DIY (very easy) get a diff fluid hand pump.
It makes the job a Piece of Cake
Old May 13, 2008 | 04:10 PM
CalgaryG's Avatar
I currently live in an apartment building, so won't have my own garage/driveway for a couple years at least.... I'm hoping to get away with having Midas or Mr. Lube or whoever do it for me for the next little while
Old May 15, 2008 | 04:28 PM
clutchless's Avatar
Stay with the Nissan Coolant.
Marlin84
Apr 1, 2020 12:52 PM
f22raptor
Mar 18, 2016 08:50 AM
BradMD_96
Oct 6, 2015 09:31 AM
AL8782
Oct 3, 2015 10:26 AM
