Gas Problem
Old May 21, 2008 | 09:21 AM
g35panama's Avatar
Gas Problem
ive posted this before but didnt understand what to do about it, I have an 04 G35 coupe automatic,,, my problem is that im filling up my car with about 8-10 gallons i tried everything possible to put more gas in to it but nothing, and the gas gauge reads full,, and im only getting about 100 miles per tank,, what should i change,,, is it the filler or one of the sending units (if so how do i know which one?)..
Old May 21, 2008 | 10:17 AM
G35fromPA's Avatar
As I and others have already posted, there's no way to know without taking it to your dealer and having them check it out. Knowing whether the sending unit(s) is(are) out can only be determined by testing the electrical resistance on the units, which is not something you can easily do. Replacing the shutter valve requires emptying and removing the fuel tank, which is not an easy DIY.
Isn't your car under warranty? If not, bring it and tell them about the TSB and ask them to cover it, or at least give you a break since it's a known issue. You're not going to fix this on your own.
Old May 21, 2008 | 01:08 PM
hyperlite21's Avatar
i had the same problem with mine except it read empty take it to the dealer its a bad floater gauge or something along those lines
Old May 21, 2008 | 02:12 PM
JZ's Avatar
JZ
G35 Coupe KY0
Mine doesnt read full but wont let me pump anymore after about 12 gallons... It gets me about 200+ miles but I wanna fill the damn thinkg up.
Old May 21, 2008 | 02:13 PM
g35panama's Avatar
i have the same problem, i think its the sending unit
Old May 24, 2008 | 01:58 PM
rheeG35's Avatar
I had the same problem ( 04 6MT). I took the car to the dealership and they said the gauge cluster was messed up. Dealer fixed it under warranty.
Freeman186
Sep 6, 2023 10:07 AM
magnetism80
Feb 1, 2019 10:00 AM
bryanr
Drivetrain
Sep 30, 2015 06:31 AM
Rhinos7777
Sep 6, 2015 05:36 PM
Jnm07
Sep 5, 2015 01:16 AM
