Warning light please advise!
I have a 05 g35c and on my way to work this morning I got the tire pressure monitoring light. I'm going to check the pressure when I leave though they do not appear low. So my question is what else could be causing this and secondly what pressure should oem 19" rays have in them? Thanks!
was it cold in the morning? that happened to me a couple times when the warning light would come on cause of the cold air in the morning. after driving it a little bit, it would go away. but as a precaution i still went and filled up to 35psi all around.
Well I stopped and checked all the tires and the right rear was down to around 27 so I filled it up to around 37 and the light went off. Seems I may have a slow leak in that tire so I will have to keep an eye on it. Thanks for the help!
mjfenix
Jul 17, 2015 02:07 PM
