6MT gear when parked
Re: 6MT gear when parked
I don't, e-brake only. But I'm always parked level.
2 G or NOT 2 G, there is no question!
'04 Coupe 6MT: DG on BLK, Prem, Sport, Nav, Custom Tint, K&N Intake/Filter, Gordgee's Grounding Gear SOON!
--License Plate: RANDYS G...say HI if you see me!
First on bad hills, plus cut the wheel accordingly. My ebrake is a lil loose (I have to JACK it up on my parents driveway) so I tend to use 1st even when unnecessary. It is in no way a replacment for the ebrake though.
2003.5 G Coupe premium. 6MT Black/black
Come join the G35Driver chat on EFnet. Channel name is #G35Driver. Catch me on aim (Xtreme03s10) if you need help setting up mIRC.
1st gear. Became a habit. Been driving stick for so long (20yrs? gee..im old) and had cars which had unreliable handbrakes so thats why. Once it's a habit, you'll also won't make the mistake of forgetting to put it in neutral when starting. It's automatic, you wont even think about it. Older cars that I had didn't even had the safety feature of needing to press the clutch to start the engine.
But you can put it in any gear.
4020 P3MCG6T5I
4020 P3MCG6T5I
never used to use my e-brake on my old accord or any car...and always parked on what I thought was a flat surface...one day I came back and for some reason I got a call 5 minutes later from my apartment complex telling me that my Accord was blocking the exit to my complex. Forgot to put the e-brake on. Ever since then I've always put my car in 1st gear as well as set the e-brake. You never know when you're going to forget...better safe than sorry.
"Operator, give me the number for 911!"
- Homer Simpson
- Homer Simpson
2nd, its a preference or a habit man, keep it in reverse if you want. Won't hurt the car unless you forget about it each time you start and release clutch.
Ivory Pearl / 6MT / Aero / Premium / Xenon Lights Everywhere / Mirror Tint / Injen CAI / Injen SES Exhaust / Tanabe Racing Springs / Ground Wire Kit / Apex'i S-AFC II
If I am parked facing down a hill, I'll use reverse. If I am parked facing up a hill, I'll use first. Either way, I am using the e-brake.
I remember reading (and hearing from brake mechanics) that using the ebrake on any car when parked is a good conditioner for the braking system.
I am not sure how valid it is, but maybe it does adjust the brakes a little in reference to the rotors?
-Chris
-Chris
On flat surface or parked facing uphill, put it in first gear, with e-brake on. If parked facing downhill, put it in reverse with e-brake on. As was already said, it's also a good idea to turn the wheels slightly so you would roll toward the curb if on an incline.
If your e-brake fails, or the cable is cut/ damaged, then the transmission in your selected gear won't allow the car to roll anywhere, nor can anybody push it.
That's why it's a good habit not to leave it in neutral when you park.
2004 G35C 6MT + Nav, Silverstone
Guest
Posts: n/a
If it's on a flat surface and I'm only gonna park for not so long, I just use the E-Brake and keep it in Neutral. If it's on a hill (up or down), I put it in 1st and then E-brake, but I make sure that 1st is holding the car, and then I pull up the E-brake (as the backup). If I'm parking it on a flat surface for many hours and it is raining/snowing, I only put it in 1st as my E-brake freezes a lot.
The G has a really sh*tty E-brake, I don't know why. When I first got the car, the setting was bad...I had to pull it up way too high and it wasn't strong, so I had it adjusted. Even now, it doesn't hold the car on steeper hills, which makes it hard for me to start moving (I use the e-brake method to start on a hill).
MrElussive
03 G35C 6MT
MrElussive
03 G35C 6MT
I use second, somebody explained to me once that parking the car and putting it in to first is bad. I forget the reason why but it had something to do with that fact that you use first gear more than any other gear so it's probably worn in the most, and bla bla bla bla bla bla....... basically first is bad.
But one thing i did notice which was interesting, On F1 weekend in montreal, they close off Peel street (downtown) and allow all ferrarri drivers to park their ferraris so people can look at them.
It's pretty cool something like 20-30 ferraries show up. Anyhow, i looked at all the ferraries, and ALL OF THEM put their car in 3rd gear when they parked. I found this interesting.
Maybe they know something we don't
Fini G Coupe M6 in dime a dozen Silverstone.
Guest
Posts: n/a
ceeze, whoever told you that is very wrong. Yes, 1st gear wears down just like every other car. But the whole point of the gears is to be able to deal with stress. Holding the car in 1st gear is no problem at all for 1st. Just imagine how much stress 1st gear has to deal with when it has the 280hp powering its *** to push the car...and that's just part of the gear's daily life, it's totally normal.
Btw, I'm not stating that every time you accelerate, the engine is pushing 280hp to the gear, but the gears are designed to work hard. If they weren't up to the task, we'd be using a different transmission system.
I don't know about the 3rd gear thing, though...personally, I've heard that you're only supposed to use 1st or reverse.
MrElussive
03 G35C 6MT
MrElussive
03 G35C 6MT
Either 1st or Reverse, whichever gear I'm going to use when I drive it next, + parking brake every time.
Black/Willow 03.5 6MT, Premium, Navi, Aero, SAT
350Z Nismo CAI
350Z Nismo CAI
i usually use first when i'm on a hill, but i stopped by the infiniti dealer the other day to get my tire pressure monitor sensors reset and when they were done with it, there's a small incline coming out of the service area. the guy parked the car with the e-brake and left the car in 4th. don't know..
also, when you guys put the car in gear to park, do you put the car in gear then turn it off? or turn off the car then put it in gear? or does it just not matter at all?
[ 2004 G35 coupe ] - | 6MT | Black/Black | Premium |
