Blown Engine Pics...finally Got Them Today...
Old Jun 27, 2008 | 11:34 AM
  #46
g35man04's Avatar
CLUB MODERATOR
i put my maps up in another thread...and all of the Performance Shop Sponsors on the boards said that my maps looked like **** My fuel was maxed out at 5500 rpms..I was running 550cc injectors..so dont know why it was maxed....My timing map was bad as well.
Old Jun 27, 2008 | 01:01 PM
  #47
rookie's Avatar
Crank pulley bolt is a mother to try to get off.
Old Jun 27, 2008 | 02:34 PM
  #48
g35man04's Avatar
CLUB MODERATOR
yeah that is what I heard....but in order to the timing cover off I have to remove it correct?
Old Jun 27, 2008 | 02:37 PM
  #49
true's Avatar
Well there's your problem...
Old Jun 27, 2008 | 02:56 PM
  #50
rookie's Avatar
Yes, the crank bolt needs to be taken off to get the front timing cover off.
Use the biggest impact gun you can get, literally we've had to use the motor trying to turn over to get the bolt off.
Old Jun 27, 2008 | 05:16 PM
  #51
true's Avatar
Agreed. Make sure to "pop" the impact gun with your trigger finger. Doing consistent fast pulls of the trigger will break it loose.
Old Jun 27, 2008 | 06:53 PM
  #52
g35man04's Avatar
CLUB MODERATOR
if I dont have one of those....brute stength?
Old Jun 27, 2008 | 06:57 PM
  #53
rookie's Avatar
With nothing on the other end of the crank it will probably just spin the crank.
Old Jun 28, 2008 | 12:00 AM
  #54
g35man04's Avatar
CLUB MODERATOR
thats what it has been doing....so I am trying to figure this one out.
Old Jul 5, 2008 | 06:40 PM
  #55
g35man04's Avatar
CLUB MODERATOR
I got the heads off today so here are some more pics! I finally got around to getting the correct tools to get the crank pulley off...it really wasnt that hard..I want to know everyones comments on the pics below if you see anything wrong that could of lead to the reason behind it blowing...Any thoughts are greatly appreciated. I would like to know!
I thought from looking at the bottom side of the pistons they looked alittle to black to me as if there was to much fuel detonating...but im not 100% sure...Anyways the rust you see is because I had the lower plenum off of the engine for about a month and it was sitting outside for alittle bit..anyways majority of the rust is just surface rust. So it is easy to be cleaned.
Also I checked out the heads and everything looked good. So if anyone is interested in my Heads please dont hesitate to ask for more pictures...I dont know what im going to do with the bottom block part after I remove the crank...it looks alittle damage inside..i Cant tell you until I get the crank off which will hopefully be tomorrow and I can get somemore pics up.
With that being said PIcs will be posted shortly..they are loading in photobucket.
Old Jul 5, 2008 | 06:45 PM
  #56
g35man04's Avatar
CLUB MODERATOR
what the garage looks like right now:
Heads: still trying to figure out how to get the last header off..the nuts are stripped on the bolts....any suggestions?
Crank and Block:
Old Jul 5, 2008 | 06:52 PM
  #57
rookie's Avatar
Try vice grips on the nuts that are stripped, you may end up being able to back the studs out.
Old Jul 5, 2008 | 06:54 PM
  #58
g35man04's Avatar
CLUB MODERATOR
that is what I was hoping to do...I thought about trying a socket on the star part of the bolt...see if I can start it that way.
Old Jul 5, 2008 | 06:55 PM
  #59
LOLmustangLOL's Avatar
Originally Posted by krnn1cenamja
time for RB26DETT?
LOL YES!!!
Old Jul 5, 2008 | 07:03 PM
  #60
g35man04's Avatar
CLUB MODERATOR
I already have a stock G35 engine back installed..kept the MD plenum spacer, went with an ARC Intake since I was taking the performance rouute but wanted the bling..kept the polished plenum, koyo radiator and Samco hoses...here is My new engine right now.
