Headlamp removal DIY thread?
I've searched for about 30 minutes trying to find a DIY headlamp removal thread for a 2003 G35 Coupe, but haven't had any luck whatsoever. The only true reason I am looking for this is because I couldn't figure out which power fuse(s) to remove before the headlamp disassembly. I would really prefer to remove the fuse(s) rather than disconnect the battery negative cable. Any help would be greatly appreciated.
Did you check the DIY section? I think this is what your looking for.
https://g35driver.com/forums/body-interior-exterior-lighting-diy/125363-diy-headlight-housing-removal.html
Tolboothwilley™
Exterior-Vendor
Jul 28, 2016 12:42 AM
Mick_L
Aug 25, 2015 04:27 PM
yassy
Aug 9, 2015 07:31 PM
