Random lights coming on during hard braking
Old Jul 4, 2008 | 07:55 AM
The-Dream's Avatar
Lately when I brake hard from a fast speed my VCD, Slip, and Parking Brake lights go on. What does this mean?
Old Jul 4, 2008 | 08:01 AM
officerdbag's Avatar
Skidding the tires? That could explain the VDC and slip lights... On my older car if you accelerated hard or braked hard and the parking brake light came on it would mean that you are low on brake fluid and that you would have to go buy some more and top it off.
Old Jul 4, 2008 | 08:42 AM
dave's Avatar
Have you checked your brake fluid?
Old Jul 4, 2008 | 10:53 AM
mIKE's Avatar
Sounds like you're a bit low on fluids.
Old Jul 4, 2008 | 05:20 PM
JZ39's Avatar
Yep.
Just add some brake fluid.
This happened to me when I had to brake hard over very uneven pavement. It probably splashed the fluid around to the point that the sensor thought it was low. I had 1/3 of the way above the low line and this still happened.
Old Jul 4, 2008 | 10:41 PM
BW350GTskyline's Avatar
when the vdc, slip, and abs come on that means ur breaks are low and need to be changed... do they squeak and do u have brembos?
Old Jul 5, 2008 | 03:44 AM
Nin's Avatar
Nin
low brake fluid!
Old Jul 5, 2008 | 03:45 AM
Nin's Avatar
Nin
also if your brake fluid is low...odds are you're near due for a brake pad change (and/or rotors)
Old Jul 7, 2008 | 04:51 PM
The-Dream's Avatar
No brembo's but they squeak like mad.
Hasanbaloch
Feb 29, 2024 08:45 PM
Mry
Mar 3, 2023 01:03 AM
sahizzle110
Jul 29, 2015 11:36 AM
Luisgalvan33
Jul 28, 2015 05:37 PM
Lsantana757
Jul 20, 2015 09:08 AM
