G questions!!!
Old Jul 10, 2008 | 12:57 AM
LoveLife-'s Avatar
G questions!!!
My G just got delivered yesterday and I have a couple questions...
First...what does "REV" mean? It says "REV" by the speedometer
Second...when I rev high going into 1st, my clutch sticks sometimes. So far its happened 4 times. It comes halfway up then either I have to lift it or wait for the RPM's to drop and it'll come up on its own. Is this a major problem? Again, this ONLY happens going into 1st when I rev high.
Thanks in advance for answers!
Old Jul 10, 2008 | 02:58 AM
Xet's Avatar
Xet
rev means you have it set so it will flash up to a certain set-able rpm and then turn solid. thus reminding you to shift
Old Jul 10, 2008 | 10:37 AM
Crashes's Avatar
sounds like RPM lock out on your clutch, basically the pressure plate not releasing quick enough. This either means its on its way out, or its just old. either way it will need to be replaces sooner or later or....upgraded
Old Jul 15, 2008 | 01:39 AM
LoveLife-'s Avatar
the car only has 23k miles on it. so that means the previous owner probably drove it like an @$$hole right?
Old Jul 15, 2008 | 10:09 AM
Starscream's Avatar
Could be a possibility but then again the previous owner might not have known to properly drive the car. You know, slip the clutch a little too much taking of and things like that.
bryanr
Drivetrain
Sep 30, 2015 06:31 AM
JG_G35
19 Inch
14
Sep 19, 2015 09:04 PM
migurus
Sep 5, 2015 09:39 PM
TheBay
Sep 3, 2015 03:27 PM
erich2780
Sep 3, 2015 03:23 PM
