Console and Interior light problem
Old Aug 7, 2008 | 07:11 PM
Stilos's Avatar
The other night I turned my car on....when I turned on my headlights shortly after that all my interior lights shut off speedometer, radio, clock, AC and Temperature lights.....tried turning the car off and back on again same problem...but when I turned my headlights back off all the interior lights I mentioned above came back on. I did a search on here and someone said they had the same problem and what they did to fix it was to reach under and make sure the light dimmer switch was plugged in all the way.....I did that and disconnected my battery for about 2 minutes as I read that could also be a way to resolve my problem. after connecting the battery and starting my car and turning on my headlights everything came back on....BUT now my clock does not work, my turn signals blink on the outside but do not blink inside same thing with the hazard light they blink outside but not inside....my outside temperature shows 125 degrees then counts down to the present temperature and the last problem is that my tripometer always resets itself back to zero whenever I restart my car. Anyone have a clue? thanks for your time and help!
Old Aug 7, 2008 | 07:13 PM
Stilos's Avatar
I forgot to mention that I did check both fuse boxes for any burnt fuses.....and found none.
Old Aug 8, 2008 | 12:31 AM
NoirKyouto's Avatar
being an '06, isn't it still under warranty? If so take it in... but if you're over millage... dunno. Sounds like there's a short somewhere to me.
mike730
Jan 12, 2018 04:25 PM
mjfenix
Aug 17, 2017 05:49 AM
myaso
Lighting
Jul 22, 2015 10:34 PM
Jadenkid22
Jul 14, 2015 12:33 AM
