fog light help
Old May 9, 2004 | 11:33 PM
BlackG35Coupe's Avatar
fog light help
hey i just installed my 8000k foglights a week ago and the fuse has seemed to blow but i cant figure out where or which is the fust for the fog lights can anyone help me?
Black/Black 04, 5AT, Premium, Navi, Aero,Nismo CAI, 8000k hids in foglights
Old May 10, 2004 | 03:01 AM
GRider35c's Avatar
Re: fog light help
i would check the owners manual, but i have a paper due... uh... today! in 10 hours...
check your owners manual and it should be there, i think...
there are fuse boxes in the engine bay, and in the driver (and passenger i think) kick panel...
2004/BO/G/aero/splash/prem/perf/cc/22%tint/alum sport pedals/brake fluid cover
Old May 11, 2004 | 01:08 AM
Re: fog light help
checked them but nothing in reference to the fog lights
Old May 11, 2004 | 01:42 AM
DHCrocks's Avatar
Re: fog light help
I think the fog light fuses are in the engine compartment next to the battery at the realy panel. for your 8000k fogs did you use high wattage halogens? that could be the reason the fuse blew. What ever you do, don't replace the fuses with higher amperage ones as you would then only damage the wiring harness. You need to get a higher gauge wire set to bypass the stock wiring.
Old May 11, 2004 | 02:18 AM
Re: fog light help
nope regular wattage thats the wierd thing as for the fuses in the engine bay there was none specifically for the fog lights am i reading this wrong?
Old May 11, 2004 | 04:08 AM
DHCrocks's Avatar
Re: fog light help
I believe there are, I'll go check later on tonight. But you need to pull off the battery cover to get to them.
Old May 11, 2004 | 08:11 AM
Re: fog light help
thanks alot. cuz i pulled out the battery cover yesterday and looked at the fuse panel to see which one is assigned to the fog lamps and it didnt show anything
Old May 11, 2004 | 08:35 AM
DHCrocks's Avatar
Re: fog light help
ok, I checked and the fuse for the fog/high beam is in the engine compartment behind the battery. They are covered with a black plastic cover. You need to remove the battery compartment cover (access cover and trim cover) and the front cowel cover (piece just under the windshield wipers) to gain access to the fuses. There are separate fuses for left and right.
Old May 11, 2004 | 11:00 AM
Re: fog light help
your the man thanx alot dude
Old May 11, 2004 | 11:05 AM
afr0puff's Avatar
Supa Dupa Moderator
Re: fog light help
Post pics! Also against a white wall to see the color difference. What are you running for your HID?
http://www.anythingbox.net
Old May 11, 2004 | 11:57 AM
esemes's Avatar
Re: fog light help
i have the jpn PIAA 8oooK sparks too.... they're oem wattage, and should be safe....
when i went from 8500K hid's to 10000K hids, the fog's no longer matched....again.....
guess i leave em off now....
Old May 11, 2004 | 01:47 PM
Re: fog light help
they dont match at all but ill post pic's but i like the contrast i dunno it looks nice to me i guess
Old May 11, 2004 | 10:07 PM
Re: fog light help
hey tried looking for the fuse and couldnt find it is there any way anyone can post like a pic to help me out thanks kind of a noob
Machine Head
19 Inch
Mar 16, 2016 08:55 PM
cmesidewayz
Sep 29, 2015 09:28 PM
Freddy07g35
Sep 17, 2015 08:53 PM
Jnm07
Sep 5, 2015 01:16 AM
attarday
Jul 15, 2015 04:03 PM
