how to reset or disable the anti-theft system
Old Sep 19, 2008 | 09:43 PM
LMg35c6mt's Avatar
my car won't start bc both the key and the fob won't deactivate the ignition immobilizer.. how can i just eliminate this crap altogether.
i made ANOTHER thread bc the other one wasnt getting any answers and i really would like to figure this out and avoid the rape that is orlando infiniti
Old Mar 26, 2020 | 07:16 AM
TonyJayHomie's Avatar
2004 infiniti g35 sport coupe 6 speed manual RWD
[QUOTE=LMg35c6mt;3449211]my car won't start bc both the key and the fob won't deactivate the ignition immobilizer.. how can i just eliminate this crap altogether.
Did u ever figure it out???
Old Mar 26, 2020 | 04:00 PM
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
Uprev tune is the only way to disable the NATS/IVIS system. It's not uncommon for these vehicles to have a heart attack and require the keys to be reprogrammed.
Old Mar 26, 2020 | 04:19 PM
So reprograming my key 'should' fix it?
Old Mar 26, 2020 | 04:23 PM
cleric670's Avatar
BANNED!!!
Is your NATS/IVIS indicator LED solid red when cranking the engine? If so then yeah you probably just need to get it reprogrammed, or the RFID chip in the key failed. You can follow the troubleshooting steps in the FSM, section BL - Body/Locks/Security
https://www.nicoclub.com/infiniti-service-manuals
Old Mar 26, 2020 | 04:29 PM
This is what's happening to mine..
Old Mar 26, 2020 | 07:33 PM
cleric670's Avatar
BANNED!!!
Solid red light means NATS/IVIS is triggered, the ECM will still CRANK the engine but it will not open the fuel injectors or deliver spark.
Old Mar 26, 2020 | 07:35 PM
So should I try and reprogram my key or do I need the ecu/bcm reprogrammed at the dealership?
Old Mar 26, 2020 | 08:04 PM
cleric670's Avatar
BANNED!!!
You can't actually "program the key" on a vehicle, what you do is program the body control module to accept the RFID chip from the key. This is done either at the dealership with the Consult-II/III tool or through some independent locksmiths that have the tool for the Nissan BCM. Call around.
Do all your keys cause the red light?
Old Mar 26, 2020 | 08:09 PM
unfortunately I only got the 1 key when I bought the car..😥
Old Mar 26, 2020 | 08:27 PM
cleric670's Avatar
BANNED!!!
I strongly suggest you have a locksmith cut you a new key from the VIN number, the programming fee is a flat rate at the dealership, doesn't matter if you bring in 1 key or all 5. That way you have a backup key.
If you have the regular key system and not the intelligent start then it's pretty cheap for another key. If you do have the intelligent key (kind where you don't have to put the key in the ignition, either a push button or something) then it's considerably more expensive because you need the entire fob which is usually $50 at the CHEAPEST.
The Nissan programming fee is the same regardless of which type of security system you have.
Old Jan 2, 2023 | 11:18 PM
thatinfiniti's Avatar
G35 pos rn
help
i need serious help i got the uprev nats disable but my immobilizer is still tripping i have original metal key but not fob and i had a locksmith try to program it but he said my key is locked or something and when he plugged his software in it didnt go past the 1st page
Old Feb 4, 2024 | 10:39 PM
Mygalwaysbreakn's Avatar
2006 g35x sedan, Vq35de awd
Did u ever figure it out bc mine is doing the same thing?
Old Aug 23, 2025 | 11:59 PM
isaacw's Avatar
did YOU ever get it fixed? having same issue
Old Aug 24, 2025 | 09:34 PM
MaLPoPieS's Avatar
Jaguar XFR-S
You need to reprogram the key fobs to the BCM using either Consult 3+ or a reputable scan tool to has the ability to program keys OR a locksmith.
What happens is the BCM loses connection with ECM for no apparent reason (vibration, moisture, bad day..) and needs to be 'refreshed'.
I've programmed key fobs on G35s using xTool D7 and it worked out fine. If you want to disable NATS or NUTS as i call it, then you'll need to have the ECM flashed by a tuner and
the starts at $500+..
