2003 coupe pulley/belt trouble (I believe)
Old Sep 22, 2008 | 10:26 PM
805g's Avatar
Question 2003 coupe pulley/belt trouble (I believe)
So I have some mods.
Injen CAI
Motordyne spacer
UR pulley set
Fast Intentions exhaust (stock cats)
The problem I am experiencing is this: Upon starting the engine will rev up when I apply the ignition, then fall down towards idle, but at this point the engine seems to go too low and it struggles for a second but then comes alive.
I know that ^^^^ above is a horrible description. sry
AND ALSO
When I am sitting at lights and at stops my car will start to have a rattle that I am almost positive is from under the hood. It is sort of a low knocking sound...could be the pulleys...
Should I reinstall/check/align my pulleys? Is there a DIY?
Does anyone know the belt sizes for that fit the UR pulley set?
THANKS ALL
Old Sep 23, 2008 | 08:16 AM
uf20wop's Avatar
my g idles @ like 600 RPM with no accessories on, it shakes a little bit, and if you go to the back of the car and listen to the exhaust you can hear it backfire a little, but a lot of people on here have the same thing
i think it's normal because if it was knocking or misfiring, the CEL would come on
Old Sep 23, 2008 | 08:17 AM
uf20wop's Avatar
but i don't get the weird start up problem
Muski_G
Dec 1, 2023 11:11 AM
newg37
Jul 26, 2015 09:32 AM
realtalk21
Jul 20, 2015 09:07 AM
driftsucky
Jul 15, 2015 12:38 PM
